Iceberg Audio launches Beatgrader plugin: The quickest route to lo-fi
2021-10-26 09:05| ·¢²¼Õß: kotoist| ²é¿´: 769| ÆÀÂÛ: 0
ÕªÒª: Iceberg Audio launches Beatgrader plugin: The quickest route to lo-fi Iceberg Audio has announced the release of its new audio plugin Beatgrader, an effect that is is modeled on the techniques being u ...
Iceberg Audio has announced the release of its new audio plugin Beatgrader, an effect that is is modeled on the techniques being used by beatmakers to create lo-fi, underwater and distorted low ends.
We¡¯ve also added saturation to that process which allows you to add more weight. Simply select a resampling frequency button and apply saturation.
Select a resample rate to quickly remove high-end detail. Beatgrader¡¯s algorithm models off-line resampling techniques to deliver a unique lo-fi, underwater sound in real-time. Includes a saturation control to add weight.
Beatgrader features
Super-Low Latency.
Saturation Control
Works to 192kHz for VST3 and AU formats.
Resizable UI.
Intel and M1 Apple Silicon Native Supported.
The plugin is available for purchase for $19 USD.
The plugin is free to owners of Iceberg Audio¡¯s The Sub sub-bass plugin, and new users can purchase a bundle of Beatgrader and The Sub for only $39 USD until November 15th, 2021 (regular value $78 USD).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
