RØDE PSA1+ Professional Studio Arm
2021-10-9 08:48| ·¢²¼Õß: 625890| ²é¿´: 1131| ÆÀÂÛ: 0
ÕªÒª: RØDE PSA1+ Professional Studio ArmNew studio arm is ideal for podcaster, streamers and broadcasters, combining sleek looks with silent operation and stability.6 October 2021The PSA1+ pairs functi ...
6 October 2021
The PSA1+ pairs functionality with style, combining sleeks looks with silent operation, precision and stability. It features a parallelogram spring design to ensure movement is smooth and steady, even with very light or heavy microphones. This mechanism keeps the microphone placement constant when moved so it can be positioned perfectly with ease.
The internal springs are fully damped and the arm features a neoprene cover for further reduction of noise generated by movement. Additionally, the PSA1+ is equipped with rubber contact points for isolation from knocks, bumps and keyboard clicks, making it ideal for streamers using mechanical keyboards with loud switches.
The PSA1+ has been designed to perform in any recording scenario, from home gaming setups to professional broadcast studios. It can support a wide microphone weight range, from as little as 94g all the way up to 1.2kgs, with extended reach and full 360-degree rotation making it easy to position the microphone where it needs to be. It also features an integrated cable management system for both XLR and USB cables, ensuring every setup is tidy and camera-ready.
Both end-address and side-address microphones are accommodated by the flexible mounting system and the arm is compatible with all standard shockmounts. A threaded desk mount and sturdy desk clamp are included to integrate into any home or professional studio. The arm also comes pre-assembled, ensuring it is easy to set up and start using right away.
The PSA1+ is shipping worldwide now.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
