Tape Piano 2 Lo-Fi Piano Keys instrument plugin by Thenathan Thenathan has released an update to its lo-fi piano keys virtual instrument for Windows and Mac. Tape Piano 2 is a major update featuring a multi-layer architecture, a new approach to modulation, 10 high-quality effects, a new preset browser, scratch designer, and more. Tape Piano 2 Is Now Lighter, Faster, And Packed With more Features¡ And Getting the right lo-fi Keys in your DAW has never been easier. We have hopefully succeeded in bringing you a collection of awesome Piano-Key Sounds That are not only perfect for Lo-fi / Chill / HipHop but for most other genres as it has a vast array of phenomenal Presets. Tape Piano 2 features 4 samplers, each with filters, envelopes, reverse, pan, stereo width, and tuning. Texture layer can load samples, drag and drop onto the sampler or select from the bonus pack that shipped with your tape piano. Delve deeper into the sound design by assigning Mod Envelopes / LFOs to almost any control. 2 Master filters with 10 popular filter models for each one. FX modules (algorithmic, convolution reverb ¨C stereo delay ¨C soft & hard distortion ¨C 8bit degrader ¨C 2 band phaser ¨C compressor ¨C gate ¨C surgical EQ). Scaler with 17 popular scales. Over 200 categorised & diverse factory presets + Tapex 1 Presets (shareable patches). Preset randomizer. Modulation matrix page with sources and targets all over the instrument. Surgical EQ designed to instantly deliver clean and transparent EQ to your tracks. Highly compressed sample library (Tape Piano 2 is only 300 MB on your disk). Fully resizable vector/HD interface. Get inspired with realistic reels & raining animations. Large output meters and peak level readout. 4 octave piano keyboard and ¡À24 transpose control. Undo/redo controls. Available in VST/VST3 and AU plugin formats, Tape Piano 2 is on sale at ADSR Sounds for the introductory price of $29.50 USD for a limited time (regular $79.50 USD). Users of the original Tape Piano can upgrade to version 2 for $15 USD. |
