Audiolatry releases Upright Piano free virtual piano instrument for Windows
2021-9-26 13:34| ·¢²¼Õß: 9769980| ²é¿´: 798| ÆÀÂÛ: 0
ÕªÒª: Audiolatry releases Upright Piano free virtual piano instrument for WindowsAudiolatry has announced the release of a new virtual piano instrument plugin. The Upright Piano features the sounds of a sam ...
Audiolatry has announced the release of a new virtual piano instrument plugin. The Upright Piano features the sounds of a sampled Kawai upright piano.
With its 2 velocity layers and its sharp and fuzzy sound, this plugin is ideal for simple dark and sad melodies, suitable for genres such as Lo-Fi Hip Hop, Chillout, Future Pop, etc.
Upright Piano sports an easy-to-use GUI. You will notice typical controls such as attack & release, global gain, also a simple reverb. The ¡°Tremolo¡± section consists of an LFO section with LFO destination (pitch, expression, or pan), rate & depth. Underneath there¡¯s a simple lowpass/highpass filter with cutoff.
If you¡¯re wondering what¡¯s that ¡°Key¡± little knob, it simply sets the amount of noise for keys release.
Upright Piano is available as a ¡°pay what you want¡± download in VST and VST3 plugin formats for 64-bit Windows, including free.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
