With VocAlign Project 5, software developer Synchro Arts presents a completely redesigned version of their software for automatic alignment of multiple vocal tracks. That sounds very complex, and it is. The technology behind VocAlign has matured for over a decade and trust me when I say it¡¯s a lifeline. It works perfectly enough to spare you from tedious vocal alignment in post. Even for those grid-obsessed, super meticulous / draconian producers, VocAlign provides a starting point that¡¯s darn near close to finish. I consider it indispensable for tight multi-tracked performances, and it all happens quite clickly. VocAlign Project, the most affordable version, does everything a reasonably accomplished music producer may be looking for in the flagship product. Its latest version is available now, at an introductory discount (EUR 89 down from EUR 141). ADVERTISEMENT Synchro Arts VocAlign Project 5 VocAlign Project 5 from Synchro Arts should help you get multi-tracked vocal recordings perfectly in time, while sounding natural. Thanks to SmartAlign tecg, the plug-in automatically detects the sections in the recordings that are supposed to ¡°fit together¡± and pushes several tracks on top of each other. With the tightness control, you can determine how precise you want the tracks lined up. Additionally, there are presets which make it easier to get started. That aside, VocAlign¡¯s user interface has been improved again. The all-important waveform view has been revised to make it easier to catch offsets in the recordings. Moreover, the software incorporates dongle-less iLok authorization. VocAlign Project 5 Synchro Arts VocAlign Project 5 deals Until October 25 2021, Synchro Arts VocAlign Project 5 is available here at Thomann.de (affiliate link) at an introductory price of EUR 89 (down from EUR 141). The upgrade from version 3 is also reduced here at Thomann.de (affiliate link) to EUR 29 (down from EUR 46). If you bought V3 before March 16 2021, you can upgrade to the new version for free. Additionally, VocAlign Ultra and upgrades are also offered at lower prices during the introductory period. You can find the offers here at Thomann.de (affiliate link). VocAlign runs under Windows 10 or later and macOS 10.8 or later in VST, VST3, AU and AAX formats (32 or 64-bit). In addition, the software supports the ARA2 interface for direct integration into Cubase, Studio One, and Logic Pro. To authorize a maximum of two licenses, you need a free iLok account (or paid USB dongle). A limited demo version and several demonstration videos can also be found on the SynchroArts website. |
