New affordable product line from the makers of Warm
2021-8-31 08:12| ·¢²¼Õß: 5982870| ²é¿´: 954| ÆÀÂÛ: 0
ÕªÒª: 512 Audio are a new Texas-based brand of studio equipment that aim to offer professional-quality gear at consumer prices. The company were founded by the people behind Warm Audio, and it's under WA's ...
512 Audio are a new Texas-based brand of studio equipment that aim to offer professional-quality gear at consumer prices. The company were founded by the people behind Warm Audio, and it's under WA's auspices that they're releasing their debut products: a duo of studio microphones, plus a pair of headphones and a microphone shockmount and boom arm.
The Limelight is a passive dynamic microphone intended for spoken word, and aimed at the live-streaming and podcasting market. Its moving-coil capsule features a hypercardioid frequency response, intended to minimise pickup of extraneous noises, while its built-in pop filter and switchable high-pass filter are designed to remove plosives and low-frequency rumbles from your vocal recordings.
Next up is the Skylight, a cardioid capacitor microphone designed with sung vocals in mind. Its 34mm gold-plated diaphragm is housed in a capsule that gives it a cardioid polar pattern, while its sound is described as adding ¡°richness and warmth¡± to your vocal recordings.
Both new microphones are priced at just ¡ê189.99 in the UK.
The new 512 Audio Academy headphones, meanwhile, employ traditional 45mm moving-coil diaphragms in a closed-back design, and are said to combine excellent ergonomics with a ¡°superior acoustic seal¡±. They're priced at ¡ê89.99.
Finally, the two microphone accessories: the 512-Pop is a metal-mesh pop filter, priced at ¡ê54.99, while the 512-BBA boom arm offers 360 degrees of rotation via its silent, high-tension design, and is priced at ¡ê79.99.
512 Audio Skylight
For more info, check out the 512 Audio website at the URL below. All the company's products are available to buy on Amazon now.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
