Rawoltage Bad Contact
2021-8-31 07:26| ·¢²¼Õß: 5982870| ²é¿´: 858| ÆÀÂÛ: 0
ÕªÒª: Rawoltage Bad ContactRawoltage Bad ContactDoes your gear work too well? The Bad Contact vst concept is a great way to add all those imperfections like noise, knob crackling and transformer hum back in ...
Rawoltage Bad ContactDoes your gear work too well? The Bad Contact vst concept is a great way to add all those imperfections like noise, knob crackling and transformer hum back into your audio. Turn the big knob for harsh crackling, hit the power button for a nasty pop sound, or add hum and dirt with the knobs on the bottom. Then crank up the voltage to increase the volume. You can use these effects creatively to create unique beats and effect loops, or add some tasty noises to your samples and recordings.
Bad Contact is a VST and VST3 plug-in for Windows.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
