Limited-MAX 3: New plugin from LVC-Audio Limited-MAX is a specialized limiter, based on the foundation of being a capable look-ahead brickwall limiter suitable for final mixing or mastering. Limited-MAX dynamically combines several unique limiting algorithms to provide transparent limiting on all audio sources. Limited-MAX is capable of substantial levels of compression/limiting without inadvertently creating excessive amounts of audible distortion. Limited-MAX is highly configurable and suitable for a wide range of musical sources. Limited-MAX exposes all aspects of the multi-process limiting algorithm. This lets the user continually adjust and find the best sound from a vast number of options, instead of choosing from only a handful of algorithms. Other features include standard attack and release controls, adjustable look-ahead, adjustable stereo linking, and a variable style control that changes the sound and shape of the limiter¡¯s compression curve. Additionally, Limited-MAX includes a selectable DC filter and complete dithering controls, with selectable dither noise shape and psychoacoustic filtering. Limited-MAX also builds on many standard LVC-Audio features. This includes: resizable interface with options to change/save the colors of the display input and output metering that includes output true peak metering, EBU metering, and PSR waveform history display with EBU metering spectrum analyzer view and stereo vectorscope auto level control (for auditioning the sound of the limiter without volume change linear and minimal phase oversampling options More information at LVC-Audio |
