Zqueezer effect plugin injects squeezed filtering in your sounds
2021-8-14 08:44| ·¢²¼Õß: lenbes| ²é¿´: 1249| ÆÀÂÛ: 0
ÕªÒª: Zqueezer effect plugin injects squeezed filtering in your soundsW.A. Production has announced the release of its new audio effect plugin Zqueezer, an ¡°Easy Squeezy¡± effect that is designed to push y ...
W.A. Production has announced the release of its new audio effect plugin Zqueezer, an ¡°Easy Squeezy¡± effect that is designed to push your sounds to the next level.
As producers, we¡¯re all searching for that something special ¨C a quick and easy way to transform sounds beyond their original forms and push them to the next level. Some of us achieve that by using complex plugin FX chains, or even by routing audio through outboard equipment. Zqueezer is a brand new way to inject a unique flavour into your synths, bass lines and vocals.
Zqueezer features
Squeezed filtering like you¡¯ve never heard before.
Adaptive output derived from complex rendering.
Adjustable Overtone to isolate flageolet tones.
Dry / Wet dial.
Visual feedback.
Factory presets.
Full PDF Manual & Tutorial video.
Zqueezer is at available in VST, AU and AAX formats for Windows and Mac. The plugin on sale at W.A. Production at from distributor Plugin Boutique, priced $19.95 USD until September 30th, 2021 (regular $39.95 USD).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
