Native Instruments Torrent MALLET FLUX Free Download 2021
2021-7-14 17:11| ·¢²¼Õß: yueming| ²é¿´: 2261| ÆÀÂÛ: 0
ÕªÒª: Native Instruments Torrent MALLET FLUX Free Download 2021Native Instruments Torrent MALLET FLUX¨C Very sampled mallets come with an innovative arrangement.¨C Quickly compose with 270 customizable pres ...
¨C Quickly compose with 270 customizable preset scenes.
¨C Customize and align complex sequences by automating flux engine patterns
More than just mallets: Most instruments with hammers give you great sound. MALLET FLUX offers more ¨C yes, it has a beautifully selected glockenspiel, celesta, xylophone, vibraphone, and marimba, but the key to this unique device lies in its innovative sequencer and game engine. This perfect combination of rhythm, melody, and sound helps develop ideas quickly, turning simple drafts into memorable arrangements of soundtracks, musical scores, and more.
A spot for quick scoring: Go beyond the preset: 270 pre-set ¡°scenes¡± ¨C single hits in ready-made arpeggios, sequences, and multi-instrumental arrangements ¨C will help you start writing quickly. Select what you want by selecting the volume and time signature of the notes. Then play notes or chords to create unique custom patterns with an innovative automation mechanism. Flux and drone visuals use intricate effects chains to create heavenly sounds and stunning textures. Morph¡¯s visuals allow you to use the modulation wheel to dynamically change the rhythm. Adjust the plot options to create something completely new.
You can also Download: Waves Complete V9r19 Torrent
Custom Mix Parameters: Click on the original recordings of the five orchestra percussion instruments captured by SONUSCORE sampling experts and mix them easily. Adjust the mix of near and far microphones. Add a REPLIKA XT delay ¨C based on the REPLIKA XT plug-in and use different delay modes. Choose from a set of high-quality spaces, halls, and reverbs to place instruments in your favorite sound space. Experiment with use and effect to create other sounds. Select the ¡°Flux¡± preset to reach new sound limits.
MALLET FLUX is a mallet instrument library that provides rhythmic and tonal sounds: 250 universal scenes ¨C music patterns and phrases you can launch and control with your MIDI keyboard ¨C providing a variety of melodies and rhythms controlled by powerful.
Serializer. MALLET FLUX has a built-in effect series for each instrument and a global mixer that allows you to customize the ensemble in the smallest detail possible.
https://getvstcrack.com/native-instruments-torrent-mallet-flux/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
