Ableton Live 11 Suite Keygen v11.0.5 + Crack {2021} Free Download Ableton Live Suite 11.0.5 Keygen is fast, fluid, and flexible software for music creation and performance. It comes with effects, instruments, sounds, and all kinds of creative features ¨C everything you need to create any type of music. Create in traditional linear settings or improvise without timeline restrictions in the Live Session view. Move freely between the elements of music and play with ideas, without stopping the music and without interrupting your flow. Ableton Live Suite 11.0.5 Key Features: Sketch, Tweak, and Experiment In the Live Session view, you can freely mix and match musical ideas without time restrictions. Bring ideas very quickly, and it¡¯s a great place to improvise. You can play MIDI and audio loops of different lengths in any combination, without ever stopping the music. Get into The Details The Settings view is where you can manage music along a timeline. Put the pieces of music in place and make a part of your song. Get into the details without losing your musical goals ¨C whether you¡¯re developing an initial idea or organizing a full song. Or you can save everything you do in the Session view in the settings to improvise your way to the finished song. Get Your Ideas into Live Whatever form of inspiration, Live gives you a way to get there. Record hardware synths, software plug-ins, drum machines, guitars, or any other real-world audio. You can now use Capture MIDI to record notes after playing them, turning your most spontaneous ideas (and accidents) into music. And there is live audio to MIDI function, which lets you change the drums and melody or harmony to MIDI patterns that you can edit and reuse with your own voice. Use Any Sounds, At Any Tempo One of the things that make creating with Live so smooth is the ability to change the tempo and time of any audio, in real-time, without stopping the music. We call it a distortion. Use twisted keys to mix and match loops of various tempos, correct time errors in recorded performances, or radically reshape any audio in a new direction of sound design. Build Your Sound with Live¡¯s Instruments The original Live device is the basis for live sound design, including synthesis of the wavetable, FM, and physical modeling. A flexible synthesis architecture with an intuitive interface makes in-depth programming more accessible. And you get the most out of your sample with a pair of live sampling instruments, thanks to innate cutting and curling capabilities, multi-sample playback, etc. Effects for Shaping Ideas, Designing Sounds, and Finishing Music Live comes with the tools you need to spark ideas and shape your voice. Use MIDI Live effects for creative manipulation of your composition. Or use live audio effects to get the sound you¡¯re looking for: clean up your mix with precision tools, or create creative chaos with noise, distortion, and saturation from analog models. Sound Selections The sound for creating all types of music is part of Live. Core Library ¨C which is included with all Live editions ¨C comes with a rich collection of vintage synths, analog drum machines, multi-sample drums, electric pianos, and other acoustic instruments. Also, there are organized collections, selected sound toolboxes from selected scenes ¨C instrument racks, clips, and samples, designed to be printed and shaped into something new. Get Hands-On Using Push Push is the best way to use Live directly. Arrange rhythms and melodies, cut samples, and sculpted sounds. Combine your music and create whole songs, all without thinking about your computer. And each update of Live brings new features, which means getting closer to Push. Export Your Live Set from IOS Apps Catch ideas wherever you are and go deeper into Live ¨C use the new Live Set Export feature, now available in several iOS apps. Take Control Live broadcasts improve when they are Live. Buttons, faders, and folder buttons control almost all parameters. Live works with MIDI controllers and includes instant mapping for ever-increasing numbers, for instant playback. Play in Time with Other Devices Expand your settings and collaborate with others using Links. This technology synchronizes time management via a network connection, which facilitates live playback with software such as Reason, Serato, and an increasing number of iOS applications. Get More Sounds, Loops, and Samples Packages are additional instruments, effects, loops, and sample collections for use in Live. Each package is created specifically by the lead sound designer and the contents of the package are ready to use, without a license, in your music project. Customize Live: Connect with the World Around it Max for Live is a software platform that supports various Live instruments and effects. You can use it to personalize your device, create your device from scratch, and even change how Live works. Or open up a world of possibilities and connect to lights, cameras, sensors, surround sound settings, etc. Make Every Show Unique One of the things that make Live great for performance is its flexibility. You can design your unique combination of instruments and effects and use eight Macro buttons to control several parameters. On stage, you can trigger, rearrange, and mix your music in real-time. And use flexible MIDI mapping to define almost all parts of Live to be adjusted directly with your controller. The Hub for your Performance Use Live to collect your performances. Control external equipment, integrate collage effects or mixers. Improvise yourself, resample sound in real-time or process audio played by someone else. If you are playing with multiple music apps, our Link technology can manage multiple devices in a timely fashion on the same network. For Any Stage Whether solo on stage or in a group, artists rely on Live to organize their performances. Some even go beyond sound: using Max for Live to control visual projections or light installations in harmony with their music, connect to sensors, and more. Ableton Live Suite 11.0.5 New Features: Comping: Comping Live organizes multiple passes of an audio or MIDI performance into individual takes. Combine the best of many takes or find creative new combinations. Linked-track editing Link two or more audio or MIDI tracks to edit or comp their content simultaneously. MPE: MPE compatibility Add bends, slides, and pressure for each note in a chord. Add subtle expression variations, morph between chords, and create evolving sonic textures. Expression View Add and edit pitch, timbre, and pressure variations of individual notes directly in a new tab in the Clip Detail View. MPE-capable native devices Wavetable, Sampler and Arpeggiator now support MPE. Use Push¡¯s pad pressure to control parameters per note. New devices: Hybrid Reverb Combines convolution and algorithmic reverbs, making it possible to create any space, from accurate real-life environments to those that defy physical reality. Spectral Resonator Breaks the spectrum of an incoming audio signal into partials, then stretches, shifts, and blurs the result by a frequency or a note in subtle or radical ways. Play it like an instrument with MIDI. Spectral Time Transforms sound into partials and feeds them into a frequency-based delay, resulting in metallic echoes, frequency-shifted, and reverb-like effects. The Freeze function captures and holds audio. Inspired by Nature Six playful instruments and effects that use natural and physical processes as their inspiration. Created in collaboration with Dillon Bastan. PitchLoop89 This device creates jittery glitch effects, delayed digital shimmers, and outlandish vibrato to add character to sounds in the studio or on stage based on an early digital effects processor. Created in collaboration with Robert Henke. Updated devices: Chorus-Ensemble The updated version of Chorus now has a wider range of sound-shaping capabilities ¨C add vibrato, spread the left and right channels of the signal across the stereo field, and add a thick 3-delay line chorus. Redux Redux adds a wider range of sounds from vintage digital gear including harsh distortion, digital and aliasing artifacts, as well as warm and saturated 8-bit textures. Phaser-Flanger Phaser and Flanger have been combined and now feature a new, lusher sound with increased frequency and modulation ranges, expressive improvements on existing modes, and a new Doubler mode for short modulatable delay. Rack improvements: Macro Variations Store the state of Macros for later recall ¨C this is a fast way to create instant variations to sounds, or builds and drops during a performance. Flexible Macro Configuration Set your Racks up to have between 1 and 16 Macros. Randomized Macro values Randomize the state of your Macros or map the randomization button to MIDI. Live tempo following: Tempo following Live listens to and adjusts its tempo based on incoming audio in real-time, making it a dynamic part of the band instead of the tempo source that everyone has to follow. Chance tools: Note chance Set the probability that a note or drum hit will occur and let Live generate surprising variations to your patterns that change over time. Velocity chance Define ranges for velocity probability for subtle, humanized variations in the dynamics of your patterns. Follow Actions Live 11 adds Scene Follow Actions for evolving arrangements. Follow Actions can now jump to specific clips and enable and disable Follow Actions globally. New Sounds: Voice Box A comprehensive collection of contemporary vocal samples from multiple voices, a set of playable vocal instruments, and Effect Racks designed for vocal processing. Mood Reel Evocative layered instruments that combine organic and synthetic sounds with textural elements to add mood, space, and movement to productions. Drone Lab Sustained tonal and textural samples, generative noise, multi-sampled instruments, plus devices, and Effect Racks designed for experimentation. Upright Piano Upright Piano is close-recorded for an intimate feel ¨C a classic sound that is at home in many styles of music. Created in collaboration with Spitfire Audio. Brass Quartet This instrument highlights the natural breathiness, range of expression, and broad tonality of the brass quartet. Created in collaboration with Spitfire Audio. String Quartet This combination of two violins, viola and cello have a sound that is immediately intimate and is also a great starting point for sonic exploration. Created in collaboration with Spitfire Audio. Updated Sounds: Updated Core Library Live¡¯s Core Library is expanded, focusing on contemporary music production, including new drum kits, Instrument Racks, Audio Effect Racks, Grooves, loops, and MIDI clips. Plus, improved browsing makes sounds easier to find. Updates to AAS instrument interfaces The user interfaces of all instruments made in collaboration with Applied Acoustic Systems have been updated. Updated Packs Drum Booth features a new MIDI drum library and mix-ready presets. Grand Piano and Electric Keyboards now come with MIDI licks, phrases, and progressions. MIDI drum grooves and instrumental parts have been added to Chop and Swing, Skitter and Step, Drive and Glow. More Additions: Refined clip editing Edit loops of multiple clips simultaneously, focus on a single clip in context, and easily transpose entire arrangements from one piano roll. Improved Clip Detail View New tabs for Note Parameters, Follow Actions, Envelopes and MPE provide a clearer overview of and access to parameters and properties of a Clip. Improved CPU metering An updated master display can now show current and average CPU usage, plus per-track CPU meters show which tracks in a set use the most processing power. Keys and scales Use scales directly in Live¡¯s MIDI editor as a guide or reference ¨C this is linked to Push and can be changed per clip. Changes to Push: Visualizations for new devices See visualizations of key parameters in Hybrid Reverb, Spectral Resonator, and Spectral Time on Push¡¯s color display and control them directly from the hardware. Key and Scale sync The Key and Scale feature in Live 11 is linked to Push and can be changed per clip. Polyphonic aftertouch support Apply different levels of aftertouch to individual notes when using Wavetable, Sampler, Arpeggiator, and supported VSTs for more nuanced and dynamic performances on Push. See up to 16 Macros In Live 11, access Macros 9-16 from a second page after the Rack page with Macros 1-8. The second page appears automatically once you map more than eight Macros. New in Max for Live: New API additions A redesigned, MPE-compatible note API gives Max Live access to Live 11¡¯s new note features: probability, velocity deviation, and release velocity. You can also now access slices of a sample loaded in Simpler, a clip or sample¡¯s warp markers, and much more. MIDI Channel Routings It is now possible to route MIDI to and from Max for Live audio effects and instruments. Inputs and outputs are routable and show up in a track¡¯s MIDI from and MIDI To choosers. Improvements for Device creators A new live.scope object adds an oscilloscope to the object library. Double-clicking an error in the Max Console jumps the cursor to the device causing the error. A new Max for Live category in the Inspector Window allows developers to more clearly indicate which systems their devices can be used on, and much more. Performance improvements A complete overhaul of Max for Live¡¯s user interface integration means a smoother experience when working with Max for Live devices, including improvements to focus, positioning, scrolling behavior, and performance. What¡¯s new in Ableton Live Suite 11.0.5? New features and improvements: Arrangement View Using ¡°CMD¡±-click (Mac) / ¡°CTRL¡±-click (Win) no longer deselects track headers that contain a hidden lane selection. Take lane headers with a standby selection are now shown in the respective standby selection color when more than one track, take the lane, and/or automation lane is selected. It is now possible to rename multiple selected tracks simultaneously. Clip View The Sample tab¡¯s Clip Gain control has been changed back to a vertical slider, and it has been repositioned above the Transpose controls. The Sample tab¡¯s Reverse button now shows an icon instead of text. The Sample tab¡¯s Reverse and Edit buttons are now positioned next to each other. Added a Pitch dial to the Sample tab, which enables shifting an audio clip¡¯s pitch in semitones. The Transpose controls now appear as adjacent slider controls, positioned beneath the Pitch control. When multiple audio clips with different Clip Gain values are selected, the value range is shown with split triangle handles on the Clip Gain slider. Added some visual refinements to the Clip View tabs. Improved the names of MIDI controllers that appear in the Control chooser when the Clip View¡¯s Envelopes tab is visible and the ¡°MIDI Ctrl¡± is selected in the Device chooser. Follow Actions The Follow Action Chance slider now displays a split triangle instead of just a black bar when it is showing multiple different values. Interface Updated various Help View lessons. Updated various Help View lesson translations in German, Spanish, French, Italian, Japanese, and Chinese languages. Updated some Japanese and Chinese info text translations. The audio engine can now be turned on or off via a new ¡°Audio Engine On¡± entry in the Options menu, or using the ¡°CMD¡±+¡±ALT¡±+¡±Shift¡±+¡±E¡± (Mac) / ¡°CTRL¡±+¡±ALT¡±+¡±Shift¡±+¡±E¡± (Win) keyboard shortcut. The Overload Indicator is disabled by default for new Live 11 installations. Live¡¯s performance is improved when deselecting many clips at once. Max for Live Updated the bundled Max build to version 8.1.11. The following new properties and functions are available in the Clip API: add_warp_marker move_warp_marker delete_warp_marker sample_rate sample_length The Max for Live API now supports large dicts. MIDI Editing It is now possible to resize the velocity, probability, and per-note expression lanes in the MIDI Editor using the mousewheel/pinch gesture while holding ¡°ALT¡±. The background color of lane headers is now consistent with the Notes tab. Clicking on a lane with a standby selection now selects that lane instead of collapsing the time selection. MPE Editing The ¡°Pitch Bend Range Settings¡¡± context menu entry now appears when right-clicking in the area where per-note pitch-bend is editable. When the Expression tab is open, making a time selection in the Note Editor or the Slide/Pressure expression lane while editing per-note expression now only shows the focused lane with a selection highlight, while all other lanes are shown with a standby selection highlight. When the Expression tab is open, using the ¡°Zoom to Clip Selection¡± command (or ¡°Z¡± key shortcut) now adjusts the zoom level according to pitch bend values contained in the time selection. It is now possible to clear all per-note Pitch, Slide and Pressure expression envelopes of a note at once by using the ¡°Clear All Envelopes¡± entry in the context menu of the per-note expression breakpoint editor. Multi-Clip Editing When clips are selected/unselected in the Session View, the highlighted track and scene now point to the foreground clip, if any exists. Changing the foreground clip from the Clip View updates the highlighting of the track (in both the Session View and Arrangement View) and the scene corresponding to the new foreground clip. Clicking on a clip¡¯s multi-clip loop bar in the Clip View updates the highlighted track, even if this clip is already the foreground clip. New Devices and Device Improvements: The enabled/disabled state of a plug-in device¡¯s MPE Mode is now saved with that device¡¯s default configuration. Plug-in devices now look similar to built-in Ableton devices when disabled. Chorus-Ensemble: The Chorus-Ensemble device now uses less CPU when certain settings are applied. Phaser-Flanger: In the Phaser-Flanger device, when the LFO Stereo Mode is set to Spin and the Spin value is changed, a second LFO line is now visible and its frequency changes accordingly. Spectral Resonator: The Spectral Resonator device now uses about 15% less CPU. The Spectral Resonator device now uses about 20% less CPU when very few partials are audible. The spectrogram should now display about 30% of its former CPU load. Note: this is only visible in the system¡¯s CPU monitor, not in Live¡¯s audio processing meter. When low polyphony and unison voices are set, less CPU usage should be shown. Spectral Time: The background of the Stereo slider now displays a blue color when its value is above 0%. ¡°Freeze On/Off¡± is now called ¡°Frozen On/Off¡± in Automation Mode and on Push. ¡°Delay DryWet¡± is now called ¡°Delay Mix¡± in Automation Mode, and ¡°Mix¡± in the device UI and on Push. In the Spectral Time device, the spectrogram should now display about 30% of its former CPU load. Note: this is only visible in the system¡¯s CPU monitor, not in Live¡¯s audio processing meter. The Spectral Time device now runs at about 60% of its previous CPU load. Wavetable: Added support for Drum Rack chokes groups to the Wavetable device. Push When editing multiple MIDI clips at once, a connected Push device now follows all highlight changes of tracks/scenes and the focus on the corresponding track. Updated the notification style for scenes, and updated the scene name visualization to include the absolute position, tempo, and time signature on Push. Adjusting multiple encoders while recording automation now creates fewer undo steps on Push 1 and 2. Session View When a Session track slot is highlighted but not selected, using the Arrow Up/Down keys, Home/End, or PageUp/PageDown keys now move the highlight to the adjacent track slot in the given direction. It is now possible to rename multiple selected scenes simultaneously. It is now possible to rename multiple selected tracks simultaneously. In the Session View¡¯s Track Status display, the remaining playtime of an unlooped clip now always displays the seconds with two digits (e.g., ¡°10:07¡± instead of ¡°10:7¡±). Control Surfaces Added support for the Roland Fantom. Added control surface support for the M-Audio Hammer 88 Pro, Oxygen Pro Mini, and Oxygen MKV Series. The functionality of the Oxygen Pro control surface script has been drastically changed. Specifically: The Rewind and Fastforward buttons will now rewind and fast forward the Arrangement position. Turning the Encoder will now scroll the Session frame up and down. Holding the Encoder down and turning it will scroll the selected Scene up and down. The Knobs can now control multiple features (Device parameters, Track Panning, Track Sends, and, in the case of the 25 keys, Track Volume) that can be selected by holding down Shift and pressing the Pads used for DAW KNOB CONTROL. Additionally, it is possible to toggle between controlling Send A and Send B by holding down Shift and pressing the SENDS Pad. Live¡¯s Takeover feature is now enforced for the Knobs and Faders when switching between DAW and Preset Modes. The Pads now provide LED feedback in respect to Clip/Clip Slot states in Live. The Buttons beneath the Faders can now control multiple features (Track Arming, Track Muting, Track Soloing, and Track Selection) that can be toggled between via the Mode button. Fixed an issue where the Session frame was visible even when the hardware was not connected. Bugfixes: Arrangement View Fixed an issue where Live hangs when zooming in Arrangement View in some cases. Previously, reordering automation lanes via dragging and dropping or using the ¡°CMD¡± and Arrow Up/Down (Mac) / ¡°CTRL¡± and Arrow Up/Down (Win) keys would not mark the document as modified. Fixed the width of the divider line between Arrangement lanes and track/lane headers. Previously, after selecting content by clicking on the Arrangement loop brace or pressing ¡°CMD¡±+¡±A¡± (Mac) / ¡°CTRL¡±+¡±A¡± (Win), the content of tracks nested in a folded Group Track would not be selected when unfolding the containing Group Track. Previously, track lanes and headers could not be deselected via ¡°CMD¡±+click (Mac) / ¡°CTRL¡±+click (Win) when their tracks contained hidden and selected automation lanes, take lanes, and/or Group Tracks. Fixed a crash that could occur when restoring the Arrangement View¡¯s zoom state using the ¡°Z¡± keyboard shortcut after deleting a take lane. Fixed a crash that could occur when clicking in a track¡¯s main lane after track content had been selected during recording, under certain circumstances. Previously, mixer controls in linked tracks would still be linked when selecting a take lane, after multiple track headers had previously been selected. Arrangement clip headers no longer have an uneven appearance. Previously, an Arrangement clip header would not be displayed as having a standby selection when the focus was moved away. Previously, it was not possible to unlink all tracks when some tracks were nested inside a Group Track. Fixed a crash that occurred when inserting a take lane. Fixed a crash that could occur when trying to move a selected main automation lane by pressing the ¡°CMD¡± and Arrow Up/Down (Mac) / ¡°CTRL¡± and Arrow Up/Down (Win) keys. Control Surfaces User Remote Scripts work as expected on Windows again. Devices The EQ Eight device will now scale the displayed spectrum the same way as the Channel EQ and Hybrid Reverb devices. Previously, the Operator device could crash or calculate inaccurate frequencies when its Fixed Mode and Spread parameters were enabled. In the Spectral Resonator and Spectral Time devices, the limiter¡¯s LED now correctly lights up when the limiter is active. Switching between oscillator effects in the Wavetable device now changes labels within each matrix as expected. In the Sampler, Simpler, and Wavetable devices, the MPE label text now updates according to the device¡¯s selected/deselected state. Previously in the Spectral Resonator and Spectral Time devices, gaps would sometimes appear in the Spectrogram at high frequencies. A Max for Live device¡¯s background color now updates correctly after moving that device between tracks. Fixed two bugs in the MPE Control device: The Pressure curve would not follow Live¡¯s themes when the device was instantiated while using the Dark theme. Global PB would be interpreted as Note PB under certain circumstances. The Surge Synth Team¡¯s ¡°Surge¡± VST/AU plug-in device now has its internal MPE Mode activated by default when started in Live. Deactivating the device¡¯s MPE Mode in Live will also cause Surge to deactivate MPE Mode internally. Interface Improvements Mouse-clicks on a return track no longer ¡°fall through¡± to audio/MIDI tracks or Group Tracks that are covered by that return track. When left-clicking the CPU meter, the drop-down menu that appears is now aligned at the left-hand of the CPU meter. The Launch Macro Variation button can be mapped as expected again. Fixed a crash that could occur when dragging an empty frozen MIDI clip to an audio track. Fixed a crash that could occur when freezing a track after recording, under certain circumstances. Fixed the alignment of the Launch text label that appears in the expanded view of the Clip View¡¯s Clip box. Previously, when copying a folder with audio files to another folder that was already in Places, the files would not appear in the browser. Previously, when saving a Live Set file (such as a clip or preset) in the root folder of the temporary current Project, that file would not be copied over to the final destination Project. Fixed the spelling of the ¡°Sostenuto¡± parameter that appears in the Control chooser when the Clip View¡¯s Envelopes tab is visible and the ¡°MIDI Ctrl¡± is selected in the Device chooser. Previously, resizing the Device View, as a result of switching to the Arrangement View, while no clip was selected would result in automation lanes having the wrong height when switching back to the Session View. Previously, using Tempo Follower and Tap Tempo at the same time could create a conflict with Live¡¯s tempo. To prevent this, Tempo Follower is now disabled as long as Tap Tempo is active. Previously, the waveform of an audio clip in the Detail View would be displayed in a dimmed color, although that clip was not audible while Audition Mode was enabled. Using pinch gestures to zoom once again works in expression lanes. Previously, the vertical zoom level and scroll position in the MIDI Note Editor was sometimes wrong when switching from the Expression tab to the Notes tab. Added the following changes for Windows: On Windows 10, Live requires version 1803 or higher to be used on HiDPI screens. Live¡¯s second window is no longer shown separately in the list of windows that appears when pressing ¡°Alt¡±+¡±Tab¡±. It also cannot be minimized anymore. These changes highlight that the second window is not a stand-alone window, but secondary to the main window. When switching virtual desktops, floating windows are no longer shown on the new virtual desktop. When using virtual desktops, floating windows (e.g., the Max editor, plug-in devices, or Live¡¯s Preferences) are now only shown on the virtual desktop where Live is. Fixed a bug that enabled performing certain actions (e.g., stopping playback) while a modal dialog was shown. Previously, the selection on an auditioned take lane would look different when Draw Mode was active. Previously, adding a device via double-clicking could create two undo steps. Fixed a performance regression when loading a Live Set with many devices. Previously, when exporting a video, the Export Audio/Video dialog would remain disabled when choosing an export file name that matched an existing video file (but not an existing audio file) and then choosing not to overwrite the existing file. Fixed an issue where a Rack¡¯s selector buttons for chains and devices would swap places, under certain circumstances. Fixed various minor UI alignment and sizing issues that affected other elements within Racks. Fixed a spacing issue in Drum Racks. In all Racks, the Rand and Map buttons now always align with the right border of the Macro Controls section, and they appear as ¡°R¡± and ¡°M¡± when six or fewer Macro Controls are shown. For MIDI clips, program change controls now appear in the order [Bank][Sub][Pgm] instead of [Pgm][Bank][Sub]. Fixed a crash when scrolling in the Clip View¡¯s Sample/Note Editor with the mouse button held down. Fixed a bug that generated false disk overload indications, even when no sample dropouts occurred. Previously, Link would not become disabled when opening a new Set. Fixed a crash when unfolding a nested Group Track containing a selected clip. The Pitch control in the Clip View¡¯s Sample tab once again works as expected when multiple clips are selected. The Clip Activator button once again works as expected. Previously, after selecting a Group Track header, the track highlight would sometimes immediately jump to a track within that Group Track. Max for Live Sending a getpath message to a live.object that operates upon the GroovePool no longer causes an error. Sending a getpath message to a live.object that operates upon a Groove no longer causes an error. GroovePool, Groove, and DeviceIO now all have a canonical_parent property. Replacing a licensed Max for Live device with an unlicensed one no longer creates a ¡°fake¡± device that informs the user of a missing license. Also, it is no longer possible to inadvertently trigger Temporary Demo Mode when attempting to perform another action that breaches any current limitations, in cases where a ¡°fake¡± device was created. The LOM ID of a routable MIDI input/output is now retained after moving and saving the containing Max for Live device. MIDI Editing Upon setting Scale Name and Root Note values for a MIDI clip, those values remain visible (but grayed out), even when Scale Mode is disabled. When enabled, the Scale (aka Fold to Scale) button becomes disabled (instead of grayed out) whenever folding to scale is not possible. Previously, when using the Arrow Up/Down keys in the Velocity or Chance Editor while no notes were selected, a false value was temporarily shown in the respective editor¡¯s lane header. When multiple MIDI clips are selected and the Envelopes and Expression tabs are not displayed, the Notes tab is now left-aligned. MPE Editing Previously, per-note pitch bend editing was unavailable when a MIDI Effect Rack or Instrument Rack was used, under certain circumstances. Previously, when the Expression tab was visible, making a rectangular selection of a single note in the MIDI Note Editor would incorrectly set the focus to pitch bend expression editing. Fixed a bug that caused a note¡¯s per-note pitch bend range to get reset to +/- 48 semitones when copying and pasting a track. Fixed a bug that could cause notes to be affected by expression parameters (including pitch bend) from previous notes. Previously, when the Expression tab was open and the MIDI Note Editor was folded, zooming to selected notes would sometimes scroll out of view. Push Changes to a scale or root note on Push while recording a MIDI clip are now applied to that newly-recorded clip. Session View When using a device parameter¡¯s ¡°Show Automation¡± or ¡°Show Modulation¡± context menu command while a Session clip is playing, Live now switches to the Envelopes tab in the Clip View when no clip is selected. Shift-clicking on an empty track slot in the Session View no longer changes the scene and track highlighting. Previously, the Follow Action Time marker was sometimes displayed at the wrong position in unwarped clips. Improved the text contrast in the Session View¡¯s Track Status display for unlooped clips. Previously, when triggering a scene with assigned Follow Actions after stopping Live¡¯s transport, that scene¡¯s tempo was not respected. The ¡°Stop¡± Follow Action now works as expected for scenes. Setting the scene tempo or time signature from the Python API (Max and Push) will enable the respective scene control and display the correct value being set. |
