DPA ST4015C Á¢ÌåÉù½ô´ÕÐÍ¿íÐÄÐͼÒô»°Í²Ì××°/¶Ô/ y, x& i4 [6 W" Z0 U
( \! }' p) W% B3 F
% A6 n' l2 V: }: I8 C2 ]
; D3 L8 ~% Z7 {3 D; H ST4015C
. F+ J. a3 s" k. `/ n+ g' G! _Á¢ÌåÉù¶Ô£¬Ê¹ÓÃ4015C½ô´ÕÐÍ¿íÐÄÐÍ»°Í²6 b8 y2 {+ V6 I- |
$ I8 o7 W$ @8 Q: K* tÖ÷ÒªÌØÐÔ# C: i+ ~5 ?$ Z
MMC4015»°Í²Í·¿í¹ãµÄ¼«ÐÔͼÐμÓÉϽô´ÕµÄMMP-C»°Í²Ç°Öù¦·Å£¬Ê¹¸²¸Ç¸ü¿íÀ«£¬¶øÇÒ»°Í²µÄÍâÐθüСÇÉ£¬Ò×ÓÚÒþ²Ø¡£ºÍËùÓÐDPA d:dicate¼Òô»°Í²Ò»Ñù£¬»°Í²¶ÔÄÜÓëһϵÁи½¼þÒ»ÆðʹÓã¬ÅäºÏ¼ÒôÅï¡¢Îę̀»òÏÖ³¡ÑݳöµÄÐèÒª¡£
/ w' f& h% A* P+ g0 U+ L$ n . _. ~2 T" Q! U/ ^
Ì××°°üº¬5 C1 k( f' J6 J& }# ^3 B% i# Z# Z( |
2 x 4015C ¿íÐÄÐÍ»°Í²£¬½ô´ÕÐÍ3 A6 B1 ~( a. W. K# k
2 x DUA0020 ÓÃÓÚ2006C/4006C/4011C/4015CµÄº£Ãà·À·çÕÖ# ~* a$ Q4 Q" M# J$ X
2 x UA0639 »°Í²¼Ð3 q. b4 e9 H* ]: S0 D
4 T8 O( j( P5 |, A
8 t: i8 S- c* i% ~- vSpecifications for d:dicate? ST4015C Stereo Pair with 4015C Compact Wide Cardioids
9 R0 a; e$ E0 b9 m
' T7 L% {( u8 l: }2 y/ i7 r* v2 I| Ö¸ÏòÐÔ: | ¿íÐÄÐÍ | | ¹¤×÷ÔÀí: | ѹÁ¦ÌݶÈʽ | | ʰÒôÍ·ÀàÐÍ: | Pre-polarized condenser | | ƵÂÊ·¶Î§: | 20 Hz - 20 kHz | | ƵÂÊ·¶Î§, ¡À 2 dB, at 60 cm: | 40 Hz - 20 kHz | | ÁéÃô¶È, ±ê³Æ, ¡À 2 dB at 1 kHz: | 10 mV/Pa; -40 dB re. 1 V/Pa | | µÈЧÔëÉù¼¶, A-¼ÓȨ: | Typ. 18 dB(A) re. 20 ?Pa (max. 20 dB(A)) | | µÈЧÔëÉù¼¶, ITU-R BS.468-4: | Typ. 25 dB | | ÐÅÔë±È (A-¼ÓȨ), re. 1 kHz at 1 Pa (94 dB SPL): | Typ. 76 dB(A) | | ×Üг²¨Ê§Õæ (THD): | < 1 % up to 139 dB SPL peak | | ¶¯Ì¬·¶Î§: | Typ. 121 dB | | Éùѹ¼¶, Ï÷²¨Ö®Ç°µÄ·åÖµ: | 152 dB | | Êä³ö×迹: | < 200 ohm | | ***С¸ºÔØ×迹: | 2 kohm | | ÏßÀÂÇý¶¯ÄÜÁ¦: | 100 m (328 ft) | | ƽºâÊä³öÔÀí: | Impedance balancing with Active Drive | | ¹²Ì¬ÒÖÖÆ±È(CMRR): | > 50 dB | | µçÔ´ÒªÇó (for full specifications): | 48 V Phantom power (¡À 4 V) | | µçÁ÷ÏûºÄ: | 2.8 mA | | Á¬½ÓÍ·: | XLR-3M. Pin 1: shield, Pin 2: signal + phase, Pin 3: - phase | | ÑÕÉ«: | Matte black | | ÖØÁ¿: | 58 g (2 oz) | | »°Í²Ö±¾¶: | 19 mm (0.75 in) | | ʰÒôÖ±¾¶: | 19 mm (0.75 in) | | »°Í²³¤¶È: | 64 mm (2.5 in) | | Êä³öµçѹÓÐЧֵ: | > 4 V | | ¼«ÐÔ: | +V at pin 2 for positive sound pressure | | ζȷ¶Î§: | -40 ¡ãC to 45 ¡ãC (-40 ¡ãF to 113 ¡ãF) | | Ïà¶Ôʪ¶È(RH): | Up to 90% | | Æ¥Å乫²î: | ¡À 1 dB | | ¹¤¾ß°üÏàλƫ²î: | < 10¡ã |
Specifications for d:dicate? ST4015C Stereo Pair with 4015C Compact Wide Cardioids | Directional pattern: | Wide cardioid | | Principle of operation: | Pressure gradient | | Cartridge type: | Pre-polarized condenser | | Frequency range: | 20 Hz - 20 kHz | | Frequency range, ¡À 2 dB, at 60 cm: | 40 Hz - 20 kHz | | Sensitivity, nominal, ¡À 2 dB at 1 kHz: | 10 mV/Pa; -40 dB re. 1 V/Pa | | Equivalent noise level, A-weighted: | Typ. 18 dB(A) re. 20 ?Pa (max. 20 dB(A)) | | Equivalent noise level, ITU-R BS.468-4: | Typ. 25 dB | | S/N ratio (A-weighted), re. 1 kHz at 1 Pa (94 dB SPL): | Typ. 76 dB(A) | | Total Harmonic Distortion (THD): | < 1 % up to 139 dB SPL peak | | Dynamic range: | Typ. 121 dB | | Max. SPL, peak before clipping: | 152 dB | | Output impedance: | < 200 ohm | | Minimum load impedance: | 2 kohm | | Cable drive capability: | 100 m (328 ft) | | Output balance principle: | Impedance balancing with Active Drive | | Common Mode Rejection Ratio (CMRR): | > 50 dB | | Power supply (for full specifications): | 48 V Phantom power (¡À 4 V) | | Current consumption: | 2.8 mA | | Connector: | XLR-3M. Pin 1: shield, Pin 2: signal + phase, Pin 3: - phase | | Color: | Matte black | | Weight: | 58 g (2 oz) | | Microphone diameter: | 19 mm (0.75 in) | | Capsule diameter: | 19 mm (0.75 in) | | Microphone length: | 64 mm (2.5 in) | | Output voltage, RMS: | > 4 V | | Polarity: | +V at pin 2 for positive sound pressure | | Temperature range: | -40 ¡ãC to 45 ¡ãC (-40 ¡ãF to 113 ¡ãF) | | Relative Humidity (RH): | Up to 90% | | Matching tolerance: | ¡À 1 dB | | Phase deviation for kit: | < 10¡ã8 i, W: T7 w# W" B. @8 t
# d4 X+ a& G# K5 ] | T4 {$ u7 Q- R6 g
