Drawmer MC2.1 Á¢ÌåÉù¿ØÖÆÆ÷
DRAWMER MC2.1¼àÌý¿ØÖÆÆ÷ÌØµã£º
³¬µÍÔëÉùºÍ͸Ã÷µÄµç·Éè¼Æ
ÄÚ²¿µçѹѡÔñ¿ª¹ØÏßÐÔµçÔ´
Èý¸öƽºâÁ¢ÌåÉùÑïÉùÆ÷Êä³ö£¬Íâ¼ÓÒ»¸öרÓõĵ¥ÉùµÀÑïÉùÆ÷/µÍÒôÑïÉùÆ÷Êä³ö
ËùÓеÄÊä³ö¶¼Óе¥¶ÀµÄL / Rµ¥Ôª£¬ÒÔÌṩÍêÕûµÄ¿ØÖÆµçÆ½Æ¥Åä
ËùÓÐÑïÉùÆ÷Êä³ö¶¨Ê±¼ÌµçÆ÷±£»¤£¬·ÀÖ¹µçÔ´up/downÖØ»÷
ËĸöÊäÈ룺Neutrik XLR, Neutrik XLR/COMBI²å¿Ú£¬ phono/3.5mm ²å¿Ú
Á½¸ö¶ú»ú·Å´óÆ÷Óë¸öÈ˲ãÃæµÄ¿ØÖÆ
ÄÚÖöԽ²»°Í²Óëµçƽ¿ØÖÆ£¬µ¥ÉùµÀÊä³ö²å¿×ºÍ¶ú»úÄÚ²¿Â·ÓÉ
¼á¹ÌµÄ¸ÖÖÆµ×Å̺ÍʱÉеÄÀË¿ÂÁ¸Ç
¿Éͨ¹ý¿ÉÑ¡µÄ2U°²×°Ì×¼þ°²×°µ½±ê×¼»ú¼ÜµÄÉ豸ÏäÉÏ
¼¼Êõ¹æ¸ñ
ÊäÈëͨµÀÊý 4¸öÁ¢ÌåÉù
Êä³öͨµÀÊý 3Á¢ÌåÉù£¬µ¥ÉùµÀ1£¨×Ó£©£¬1 TB
Ä£ÄâÊäÈë 2 x XLR£¬2¡ÁCOMBI£¬2¸öRCA£¬1¸öÁ¢ÌåÉù1.8¡°TRS
Ä£ÄâÊä³ö 7¸öXLR£¬1¡Á1/4
Êý×ÖÊäÈë ÎÞ
Êý×ÖÊä³ö ÎÞ
¶ú»ú 2¡Á1/4¡°
¶Ô½² ÓÐ
¸ß¶È 3.189¡°
Éî 8.465¡°
¿í 10.708¡°
ÖØÁ¿ 5.51°õ
Drawmer MC2.1 Monitor Controller Features:
Ultra-low noise and transparent circuit design
Linear power supply with low hum toroidal transformer and internal voltage selector switch
Three balanced stereo speaker outputs, plus a dedicated mono speaker/sub-woofer output
All outputs with individual L/R trims under unit to provide complete control over level matching
Timed relay protection on all speaker outputs to prevent power up/down thumps.
Comprehensive mix checking facilities including L/R Cut, Phase Reverse, Mono, Dim, Mute
Parallelled custom quad pots on main and headphone level controls for easy channel matching
Four inputs: Neutrik XLR, Neutrik XLR/JACK COMBI, and shared aux phono/3.5mm jack
Two headphone amplifiers with individual level controls
Built in talkback mic with level control, mono output jack, and internal headphone routing
Rugged steel chasis and stylish brushed aluminium cover
Can be stacked and is rack mountable (via optional 2U mounting kit)Tech Specs | Number of Input Channels | 4 stereo | | Number of Output Channels | 3 stereo, 1 mono (sub), 1 TB | | Analog Inputs | 2 x XLR, 2 x COMBI, 2 x RCA, 1 stereo 1.8" TRS | | Analog Outputs | 7 x XLR, 1 x 1/4 | | Digital Inputs | None | | Digital Outputs | None | | Headphones | 2 x 1/4" | | Talkback | Yes | | Form | Desktop; rackmount via optional 2U mounting kit | | Height | 3.189" | | Depth | 8.465" | | Width | 10.708" | | Weight | 5.51 lbs.
