MAGIX SOUND FORGE Audio Studio 15.0.0.118 WIN
Èí¼þ
Sound Forge™ Audio StudioÓÐÄãÐèÒªµÄÒ»ÇУ¬ÄúµÄ¼ÒÓõçÄÔÉϱ༭ºÍ¿ØÖÆ×¨ÒµÖÊÁ¿µÄÒôƵ¡£Â¼ÖÆÏÖ³¡ÀÖÆ÷ºÍÈËÉù£¬Ô²ÈóºÍÐÞ¸´ÒôƵ£¬ÊÊÓÃÓÚ¼ÒôÊÒÆ·ÖʵÄЧ¹û£¬ÒÔÉÁµç°ãµÄËÙ¶Èת»»Îļþ¡£ÄãÉõÖÁ¿ÉÒÔ´´½¨Äã×Ô¼ºµÄ¿¨À­OKÇúÄ¿ÓëÉùÀÖ¡£Í¨¹ý¼¸¸ö¼òµ¥µÄ²½Ö裬Äú¿ÉÒÔÔÚÄúµÄPCÉÏÖÆ×÷¹ã²¥¼¶ÖÊÁ¿µÄÒôƵ¡£
SOUND FORGE Audio Studio provides comprehensive tools and features for editing audio digitally. Record podcasts in professional quality, edit your recordings with a full range of professional effects. Digitize old vinyl and modify audio files using restoration and mastering tools for clean, professional sound. Simple workflows for professional results: Experience SOUND FORGE Audio Studio.
Recording
Professional recording made easy: Record vocals, sounds and podcasts in excellent quality at up to 32-bit/384 kHz with this fast, uncomplicated and reliable audio editor.
Audio editing
Cut, move and edit audio files easily and in a matter of clicks. Achieve perfect results for the project you¡¯re editing in no time at all with professional effects and 64-bit power on up to 6 channels.
Restoration & mastering
Convert old vinyls and tapes to digital audio files and clean up the recordings using professional restoration tools. Export your songs for streaming and CD release using high-quality mastering effects.
Highlights:
¨C NEW! Remote Recording
¨C NEW! Instant Action & Windows context menu extensions
¨C NEW! wizardFX Suite with professional effects plug-ins
¨C NEW! Truncate Silence option for removing pauses
¨C NEW! ACX Export Wizard NEW! Redesigned Visualization Meter
¨C Customizable user interface with four shade settings: Dark, Medium, Light and White
¨C Event Editing tool for professional, versatile and dynamic editing of audio files
¨C Edit 5.1 Surround files with up to six channels
What¡¯s New in SOUND FORGE Audio Studio 15?
Remote Recording
The Remote Recording Window enables a highly convenient control of the recording process. Simply place the sleek remote window anywhere you want like next to the text of your audiobooks and begin recording right away.
wizardFX Suite
Unique operational concept: wizardFX Suite provides diverse effects for dynamics, coloration and modulation with a massive selection of presets. Ideal for giving your recordings a more powerful and creative sound.
Instant Action & context menu extensions
Now, even more tools are directly available to you with the Instant Action & context menu extensions. Perform basic tasks with just one click to help achieve a faster workflow.
Release Notes
System Requirements:
¨C Windows 10, Windows 8 (64-bit)
¨C Processor: 1.4 GHz
¨C Graphics card: Onboard, minimum resolution 1024 x 768
¨C Program languages: English, Deutsch, Español, Français, Polski
Homepage
https://www.magix.com
ÆÀÂÛÁÐ±í£¨1£©
лл·ÖÏí°¡
2022-3-8 14:40:59 »Ø¸´
