空气感AIR插件 – Rothmann Roth-AIR 1.0 for Win/Mac
Roth-AIR是一种混音工具,可轻松为您的音频添加通风的、清脆的存在感。
AIR: Adds most of the airy effect – It controls a combination of compression ratio and saturation amount
添加大部分通风效果 – 它控制压缩比和饱和度的组合
THRESH: Sets the threshold of the compressor. Lower values give more extreme compression
设置压缩器的阈值。 较低的值会产生更极端的压缩
FREQ: Sets the crossover frequency from which air is added. It goes from 1000Hz to 8000Hz
设置添加空气的交叉频率。 它从1000Hz到8000Hz
GAIN: Controls the overall gain of the AIR layer
控制AIR层的整体增益
MIX: This mixes dry/wet between the original signal and the AIR effect – use this to dial in the overall effect amount after setting the desired compression amount with “AIR” and “THRESH”.
MIX控制原始信号和AIR效果之间干/湿混合 – 使用此选项在用“AIR”和“THRESH”设置所需的压缩量后发送的总效果量。
