Audentity Records Pop Vocals ºÍ FX 2 WAV-FANTASTiC
2022-11-16 22:47| ·¢²¼Õß: 78523580| ²é¿´: 1044| ÆÀÂÛ: 0
ÕªÒª: Audentity Records Pop Vocals ºÍ FX 2 WAV-FANTASTiCVocal Pop FX 2 Êdzɹ¦µÄ Vocal Pop FX ϵÁеÄÐø¼¯£¬ÒÔÆäÓÅÃÀµÄÈËÉù¡¢ÈËÉù¡¢ÀÖ¾äºÍЧ¹û¶øÎÅÃû¡£Pop Vocals FX 2 ÄÚ²¿ÓÐ 4 ¸öÍêÕûÇÒÍêÕûµÄ°¢¿¨±´À­£¬´øÓÐÊýÁ¿ ...
Vocal Pop & FX 2 Êdzɹ¦µÄ Vocal Pop & FX ϵÁеÄÐø¼¯£¬ÒÔÆäÓÅÃÀµÄÈËÉù¡¢ÈËÉù¡¢ÀÖ¾äºÍЧ¹û¶øÎÅÃû¡£
Pop Vocals & FX 2 ÄÚ²¿ÓÐ 4 ¸öÍêÕûÇÒÍêÕûµÄ°¢¿¨±´À­£¬´øÓÐÊýÁ¿¾ªÈ˵ÄÏêϸ˫´ò¡¢ÉùÂëÆ÷¡¢ÈËÉù¼ô¼­¡¢ÈËÉù¾µÍ·¡¢ÈËÉùЧ¹ûÆ÷ºÍÐýÂÉ£¬Ëü×ܹ²ÓÐ 222 ¸öÑù±¾ºÍÑ­»·¡£
ÎÒÃÇÍêȫרעÓÚ 100% È«ÐÂÇÒÓÐÓõÄÈËÉù¡¢ÍêÕûµÄÎÞ°é×àºÏ³ª¡¢ÈËÉù¼ô¼­ºÍÈËÉùЧ¹û¡£ÎªÁËʹ°ü¸ü¼ÓÍêÕû£¬ÎÒÃÇÌí¼ÓÁ˵¥·¢¡¢º°½ÐºÍ¶ÌÓï¡­¡­ÕâÊÇÖÕ¼«µÄÉùÀÖһվʽÉ̵ꡣ
The acapella's have been divided into verse, pre-chorus, and chorus, which contain the dry and wet versions, they also contain all the backing layers. The Vocal FX are atmos, gated, whispering, reverse vocals, Vocoder stuff, and much more, all made from the vocals. So very unique sounding.
All chopped and processed, ready to be dropped in your DAW or samplers.
Note: This is a full vocal pack, additional sounds & samples were used in the demo for demonstration purposes (synths, guitars, pianos, drums, drum loops, and FX samples are not included in the pack)
•65 one shots
•156 loops
home page
https://bit.ly/3hCEkvo
ÏÂÔØ
peeplink.in/8f995feb6763
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
