Distox v4.0 by Analog Obsession
2022-8-7 14:52| ·¢²¼Õß: davnci| ²é¿´: 1883| ÆÀÂÛ: 0
ÕªÒª: Multi-mode distortion plugin. A tube and an op-amp circuit with different op-amps and tubes.Features- INPUT(dB): -30 to 30- OUTPUT (dB): -30 to 30- HPF: 20Hz to 2kHz- LPF: 20kHz to 10kHz- MODE: 2 circ ...
Features
- HPF: 20Hz to 2kHz
- MODE: 2 circuits. 3 op-amps and 4 tubes. Same circuit and different op-amp/tube models for each circuit.
- 4x oversampling (ANALOG OBSESSION LOGO: Oversampling. It will turn to red when oversampling is engaged. Also, show you a notification.)
22/8/2021 - v4.0 Update
- Improved DSP and circuit design
- Added 4x oversampling
- Readout for knobs
- Catalina & Big Sur (Intel/M1) support
Available Formats
VST/VST3/AU | Mac 10.9 - 11.X
VST/VST3 | Windows 7 - 8 - 10
Patreon
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
