2B Played Music releases 2B Controlled v2
2022-7-28 11:28| ·¢²¼Õß: 8539700| ²é¿´: 651| ÆÀÂÛ: 0
ÕªÒª: 2B Played Music released an updated version of 2B Controlled, a dynamic stereo / mid / side frequency processor / enhancer.2B Controlled is a plug-in built to help you:Enhance your track/kick low end. ...
Enhance mid/side frequencies.
Control and enhance stereo frequencies.
Enhance vocals/drums/bass.
High pass track parts while keeping them strong.
Control your master stereo/mid or side frequencies.
Here's what they say:
2B Controlled consists of a unique combination of filters combined with the so-called pull-push technology. There are 4 modes to choose from: Pitch, Classic, Trimmed and Single. With all 4 modes you can choose between: Stereo Processing, Mid Processing or Side Processing.
In addition to a new design, the new 2.0 version of 2B Controlled also received a Limiter and Oversampling function. Also, the plugin has become self-explanatory, which helps to explore the options. Furthermore, 2B Played Music indicates that 2B Controlled is now also available in VST3 format for macOS in addition to the already supported AU version. 2B Controlled is compatible on macOS with both Intel and Apple Silicon chips. For Windows, the well-known VST3 format is supported.
2B Controlled v2.0 is now available for Windows and macOS with an intro offer at the 2B Played Music website.
Price:15,50 Excl. VAT.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
