Acustica Audio launches Graphite bass amp effect plugin Acustica Audio has introduced an all-in-one, super light and easy-to-use plugin that recreates the natural transparency and ¡®pure sound¡¯ of the GR Bass One head stacked with the carbon fibre bass cabinet. The Acqua series Graphite plugin can be used to sculpt your sound with absolute realism for both tracking and mixing. The challenge was to faithfully recreate the sound of the GR Bass One head in combination with the AT 212 bass cabinet, both produced by GR Bass. The GR Bass One head is designed according to their ¡®PURE SOUND¡¯ philosophy, producing a realistic sound with natural transparency. The AT 212 bass cabinet is the lightest 2¡Á12¡å cab available in the world: it is part of the revolutionary AeroTech series, and an example of the incredible technical advancement that GR Bass has achieved with its Carbon Fiber cabinet line. Thanks to its intuitive single-screen interface, whatever musical style you are playing, fingerstyle, pick or slap, this plug-in will adapt, providing you with the pure sound and punch of the GR Bass ONE head and the AT 212 cabinet, for a huge amount of ultra-solid bass tones ready for any genre! For any further tuning and sculpting of your sound, please don¡¯t forget to use the powerful 4-band equaliser, then add to the output mix any dose you like of your D.I. signal by using the relevant controls at your disposal. Available in VST/VST3, AU and AAX plugin formats for Windows and Mac, Graphite is on sale for the intro price of 69 EUR until August 16th, 2022 (regular 99 EUR). |
