TAL Software TAL-Dub-X v2.0.0 TAL-Dub-X is a remake of the popular original freeware TAL-Dub plug-in with a lot of additional features and AAX, OS X 64bit support. TAL-Dub-X is no emulation of a specific hardware delay effect and it has its own special sound. Don¡¯t expect one of the very clean digital delays. An important part of the delay is a special saturation stage and a high quality low pass filter with resonance setting. This makes the delay suitable for endless delay effects. It¡¯s possible to use MIDI automation to control the parameters. Version 2.0.0 / 30.05.2022 - Ducking mode added. - Host sync mode with adjustable phase control added. - New LFO waveforms (S&H, SAW, SINE, TRIANGLE, PULSE, NOISE). Other features: Drive knob controls saturation High quality resonance filter High pass filter Delay time up to 2 seconds Host tempo sync TAP button Feedback and POST filter routing PING PONG mode Stereo triangle LFO modulation for delay time and resonance filter MIDI LEARN for easy automation Useful presets included Accurate meter |
