Xhun Audio releases KickBeat Hybrid Bass Drum Synthesizer with Introductory Offer
2022-7-12 08:17| ·¢²¼Õß: xhun| ²é¿´: 669| ÆÀÂÛ: 0
ÕªÒª: Xhun Audio releases KickBeat Hybrid Bass Drum Synthesizer with Introductory OfferXhun Audio has released KickBeat - a compact and easy to use hybrid electronic bass drum generator / synthesizer - as t ...
Xhun Audio has released KickBeat - a compact and easy to use hybrid electronic bass drum generator / synthesizer - as the first entry of its new SnapLab products lineup.
KickBeat is modeled after late-90s hybrid digital / analogue hardware generators: at its heart, it makes use of genuine 16-bit integer precision digital synthesis techniques (widely used on late-90s virtual analogue hardware devices) together with an analogue modeled, transistor-based saturation circuit.
As mentioned, KickBeat is the first entry of the new SnapLab collection / lineup by Xhun Audio: each one of the virtual devices in this lineup is specifically intended to have a very peculiar focus and scope, a simple, easy to use interface and a fair, affordable price.
Features list:
Accurate modeling achieved by the adoption of the Advanced Component Simulation (ACS) approach.
Full 64-bit processing accuracy for every single aspect of the simulation.
A complete, self-contained, hybrid digital-analogue electronic drum kick generator device.
Two independent (Bass / Snap) digital synthesis layers featuring late-90s, genuine 16-bit integer precision algorithms.
Analogue modeled transistor-based saturation circuit with load control.
Built-in digital reverberation DSP algorithm.
Including 40+ ready-to-use factory presets collection covering multi-genre styles.
MIDI automation.
Support for sample rates from 44.1 kHz up to 192 kHz.
Available in multi-size GUI resolutions.
Pricing And Availability
KickBeat (regular price: 39.00 Euro / USD) is available now for 19.90 Euro / USD by joining the time-limited, 50% off special introductory offer. This offer is available from the online Xhun Audio Shop as well as from selected 3rd party Dealers.
KickBeat is available as a VST, VST3, AU plugin for Windows and macOS (Intel CPU). Although running the software on M1 macOS (Apple CPU) is possible using Rosetta 2, Xhun Audio strongly recommends to download and try the demo version before buying.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
ÉÏһƪ£ºSR Musics QuantizeÏÂһƪ£ºViator DSP Vox Amp
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
