Remoter - Stream audio to your phone from your DAW
2022-7-9 09:59| ·¢²¼Õß: J37| ²é¿´: 1870| ÆÀÂÛ: 0
ÕªÒª: Remoter - Stream audio to your phone from your DAWRemoter is an audio plugin that allows you to stream audio directly from your DAW to any web browser-capable device.This is useful for quick mix trans ...
This is useful for quick mix translation checks on your phone speakers/earbuds/laptop speakers.
Simply insert the plugin, start the server, and scan the QR code to open the supporting web app in your browser. Then press connect to start streaming.
Features:
Lossless audio streaming.
Highest bitrate Opus encoded audio streaming (not yet supported on iOS).
Latency that is low enough to allow for comfortably making mix adjustments in real-time.
Configurable buffer size for finding optimal latency vs stability.
Multiple simultaneous connections are possible.
No dedicated app on the phone is needed - it works in the web browser.
Available for Windows (VST3) and Mac (VST3/AU).
Price: 20
For more information and a free trial visit https://www.sheafmusic.com/remoter/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
