Audiolatry launches Amurg and Amurg Lite (FREE) rompler plugins
2022-7-8 10:07| ·¢²¼Õß: 83068780| ²é¿´: 905| ÆÀÂÛ: 0
ÕªÒª: Audiolatry launches Amurg and Amurg Lite (FREE) rompler pluginsAudiolatry has announced the release of Amurg and Amurg Lite, two new virtual instrument plugins for Windows and macOS.The instruments fe ...
The instruments features royalty free sounds that are suitable for a wide range of styles including Ambient, Lofi, Hip Hop, RnB, Cinematic, EDM, and more.
Both plugins are identical in terms of GUI and features, the only difference being the Lite version has 33 presets instead of the 132 found in the full edition.
All the sounds were captured from hardware synthesizers only, edited, and carefully looped. Each preset is customizable with a set of controls such as ADSR envelope, modulation, filter, reverb, etc.
Available in VST/VST3 and AU plugin formats, Amurg Lite is free to download. The full version is priced $10 USD for a limited time with coupon code hi5 at the checkout (regular $15 USD).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
