Dougal-s Aether
2022-7-7 10:31| ·¢²¼Õß: t-exciter| ²é¿´: 659| ÆÀÂÛ: 0
ÕªÒª: Dougal-s AetherFree plug-ins AetherAether is an algorithmic reverb plug-in in LV2 format for Linux systems. One look at the plug-ins beautiful GUI reveals that Aether comes with a good selection of pa ...
Dougal-s Aether
Free plug-ins AetherAether is an algorithmic reverb plug-in in LV2 format for Linux systems. One look at the plug-ins beautiful GUI reveals that Aether comes with a good selection of parameters for adjusting the reverb. Both the early reflections and the reverb tail can be adjusted in great detail, and you can apply modulation. There¡¯s even a built-in spectrum analyzer that shows you exactly what¡¯s going on. If you¡¯re looking for a free, Linux-compatible reverb, this one should be on your list.
Aether is currently available as an LV2 plug-in for Linux. It¡¯s open-source, so you can also compile it for macOS and Windows if you¡¯re tech-savvy.
Ãâ·ÑÏÂÔØ£ºhttps://github.com/Dougal-s/Aether
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
