New Moog One preset pack by Matt Johnson Jamiroquai Matt Johnson of Jamiroquai celebrates the new Moog One firmware with a new preset pack with 113 custom-made sounds. Shortly before the summer, Moog released the long-awaited firmware update 1.5, which includes some new features but above all many important improvements and fixes. An update that fixed many known issues on Moog¡¯s polyphonic analog Synthesizer. Jamiroquai keyboardist and YouTuber Matt Johnson is an active user of this analog polysynth flagship. Many of his viewers have asked for Matt Johnson Moog One signature sounds. Et voil¨¤, it¡¯s out now. Moog One Preset Pack Matt Johnson The new pack features 113 custom-made presets for the Moog One polyphonic analog Synthesizer. It¡¯s tri-timbral, available in 8 or 16 voices, has 3 analog VCOs, 2 distinctive analog filters, and more. Matt says the Moog One is his pride and joy. Each preset has lots of modulations built-in available via the expression pedal and aftertouch. In the accompanying video, Matt gives a detailed insight into the included sounds. The new Moog One sound library is available now for ¡ê29,99. You can also get a note-for-note sample of the Moog sounds for Kontakt or Logic for ¡ê4,99. https://www.mattjohnsonproducer.com/product-page/moog-one-preset-pack |
