Cherry Audio Releases Galactic Reverb
2022-7-3 14:02| ·¢²¼Õß: 6753906| ²é¿´: 626| ÆÀÂÛ: 0
ÕªÒª: Cherry Audio Releases Galactic ReverbCherry Audio's Galactic Reverb is a stellar effects plugin based on the reverb algorithm in Cherry Audio's acclaimed Dreamsynth virtual synthesizer. Galactic captu ...
Cherry Audio's Galactic Reverb is a stellar effects plugin based on the reverb algorithm in Cherry Audio's acclaimed Dreamsynth virtual synthesizer. Galactic captures the expansive sound of coveted classic hardware digital reverbs. With a decay time up to 35 seconds, it enables users to create massive, beautiful aural spaces. Galactic is a natural for transporting guitars, drums, keys, and even vocals into an extraterrestrial ambience.
Galactic Reverb Features
- Authentically modeled classic reverb
- Modulation from 0.10 Hz to 5.00 kHz
- Predelay from 0 ms to 500 ms
- Decay from 0 ms to 35,000 ms
- Ducking with attenuation and recovery time controls
- Equalizer with low and high frequency controls
- Use as an insert or bus effect
- Compatible with mono or stereo input sources
- Preset browser with over 50 Presets for Drums, Ducking, Guitars, Keys, and Vocals, favoriting, and user presets
- Full MIDI control and DAW automation for all controls
Galactic Reverb is available in AU, VST, VST3, AAX, and stand-alone formats. A free seven-day demo of Galactic is available. The demo will play white noise periodically, but is otherwise unlimited.
macOS Requirements: macOS 10.9 or above (including macOS 12), 64-bit required. Native Apple M1 processor support. Quad-core computer with 8GB of RAM recommended.
Windows Requirements: Windows 7 or above (including Windows 11), 64-bit required. Quad-core computer with 8GB of RAM recommended.
See more of Galactic Reverb in action in a deep dive hosted by Nick Gourlie:
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
