Acustica Audio announces JET | The Ultimate 2-band Dynamic EQ embracing the Analog and Digital world
2022-6-24 10:25| ·¢²¼Õß: vlhalla| ²é¿´: 1634| ÆÀÂÛ: 0
ÕªÒª: About JetJet is the ultimate, all-new, 2-band dynamic equalizer plugin suite from Acustica Audio, consisting of two FREE players, JET and JET MIX, both available in VST, VST3, AU, and AAX format.The J ...
About Jet
The Jet suite is one of the most versatile and indispensable tools for all audio engineers who need to solve problems with just a few clicks without compromises, deserving a place among Acustica's flagship products due to its sound and design quality.
This suite of dynamic EQs is inspired by some very special gear that includes one of the best, renowned, and most versatile Bus Compressors made in the UK, recently reintroduced to the market in a brand new form that has already been a great success due to its powerful, yet musical sound character.
Main features
• 'Hybrid' plugin with analog and digital emulations.
• Powerful 'Glue' Compressor.
• Improved CPU performance.
• Extensive list of presets.
• Three modes of operation: Classic Stereo (L-R), Mid or Side.
• Great sounding, transparent, very musical and precise.
• Internal and External Sidechain.
• Oversampling.
• Possibility to expand the collection of emulations with additional Volumes.
• Resizable interface*
*Once the desired size has been selected, the plugin must be removed and re-loaded to apply the changes. This action affects the currently selected plugin. New instances of the same plugin will open with this magnification.
The idea behind Jet
While mixing, occasionally, a 'Static' EQ may not be enough. The problem is that sometimes we don't want or need to cut a frequency throughout the entire track; we need to cut it when it exceeds a certain threshold.
The main idea behind compressors (dynamic processors) is the dynamic manipulation of the overall level of the audio material.
Equalizers change the spectral character of the audio signal statically. Multiband processors can do both. They can be used like a filter that isn't limited to being set to a specific gain level but can change its gain settings dynamically utilizing a control signal.
In the audio market, several, often complex, tools can perform this function but are potentially destructive if not used correctly; this is why we decided to create a powerful, complete, uncompromising, yet easy-to-use 2-band dynamic equalizer for mixing and sound design.
Dynamic EQs represent a new generation of tools providing a marriage between dynamic processing and EQs.
Jet is Acustica's new dynamic equalizer; unlike our previous dynamic EQs, it uses algorithmic technology for the dynamic part and allows the [B]loading of different types of equalizers[B], including some derived from our most popular Acquas.
What you get
Jet FREE consists of:
1- Jet; a FREE player/plugin designed primarily for bus purposes.
Jet 'Bus' version GUI
2- Jet Mix; a FREE player/plugin designed primarily for mix purposes.
Jet 'Mix' version GUI
Jet and Jet Mix, by default, includes three different equalizer models for the DYNAMIC EQ section.
▶ One sampled EQ, a set of selected LF and HF band frequencies derived from our renowned Eminence Acqua plugin.
Frequencies:
- LF: 20 Hz, 40 Hz, 80 Hz, 160 Hz.
- HF: 7 kHz, 10k Hz, 15 kHz, 20 kHz.
▶ Two algorithmic EQs with a set of selected LF and HF band frequencies called 'DIGITAL SHELF' and 'DIGITAL SHELF HQ 2X'.
Frequencies:
- LF: 20 Hz, 28 Hz, 40 Hz, 60 Hz, 80 Hz, 120 Hz, 170 Hz, 240 Hz, 350 Hz, 490 Hz, 700 Hz.
- HF: 700 Hz, 960 Hz, 1.32 kHz, 1800, 2.5 kHz, 3.5 kHz, 4.75 kHz, 6.5 kHz, 9 kHz, 12.5 kHz, 17 kHz.
The signal flow of Jet is:
Input ¡ú StaticEq ¡ú DynamicEq ¡ú Output
Both static and Dynamic EQ can operate in L-R, Mid, or Side mode.
Additional Volumes
Jet Volume A
Jet Volume A includes 24 emulations of different algorithmic and sampled equalizers that can be loaded into the Dyn EQ section.
It includes:
▶ 12 Algorithmic EQs
▶ 12 Sampled EQs
Jet Volume B
Jet Volume B includes one emulation (under the name 'Motor EQ') from an ultra-rare, all-analog, passive, seven-band fixed EQ considered today as the 'Holy Grail' of classic EQs, that can be loaded into the Dyn EQ section to enrich your range of possibilities.
It includes:
▶ 1 Sampled EQ
In addition to creating the hits of the likes of Stevie Wonder, Marvin Gaye, Diana Ross, the Jackson
5 and many others, the Motown record label created the true Soul and R¡¯n¡¯B sound.
The beating heart of the equipment was undoubtedly the equalizer that was sampled and
included in this Jet Volume B, built in the 1960s by Motown engineers and considered today
as the ¡®holy grail¡¯ of classic equalizers;
We are talking about a custom passive 7-band graphic equalizer with frequencies fixed at
50Hz, 130Hz, 320Hz, 800Hz, 2kHz, 5kHz, and 12.5kHz, capable of delivering full tones and
a huge, punchy, and warm sound that made this EQ a classic.
In Jet Volume B, you can appreciate this meticulously sampled emulation to enrich the Dyn EQ section.
Note: For the full list and details of included emulations please refer to the user manual.
Important
- To install any additional Jet volume correctly is mandatory to install/update the FREE Jet (tool) first.
Jet introduction video
Technical information
• Plug-in Format(s): VST2, VST3, AU, AAX
• System Requirements
• Available sample rates: 44.1 - 48 - 88.2 - 96 kHz
• Windows 10 compatible
• M1 macOS Monterey compatible
To understand the full potential and features of Jet, we recommend reading the Jet user's manual:
Jet user's manual
How to install the free 30-day trial, free o commercial products
Note: Trials are only available in 44 kHz and 96 kHz sample rates.
Please be careful and remember that trials expire 30 days after authorization, and we strongly recommend not using trial products in commercial sessions or any important project.
Price and availability
Jet Volume A price:
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
ÉÏһƪ£ºEQP-OverloudÏÂһƪ£ºRed Rock Sound SA60 Spectrum Analyser
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
