AudioThing Things Crusher, new filtering bit crusher effect plugin
2022-5-30 22:30| ·¢²¼Õß: sacd| ²é¿´: 915| ÆÀÂÛ: 0
ÕªÒª: AudioThing Things Crusher is a new straightforward plugin that merges a multimode filter and bit crusher in a single effect processor.The Things series from AudioThing are small, super easy-to-use eff ...
The Things series from AudioThing are small, super easy-to-use effect plugins that have a workflow very reminiscent of pedals. With Rotor, for example, the developer has developed in collaboration with experimental musician Hainbach a morphing rotor effect.
The latest Things release is less experimental but a very characterful effect suitable for all kinds of sounds.
AudioThings Things Crusher
Things Crusher is a new easy-to-use plugin that combines a multimode filter and a bit-crusher in a single effect processor. According to the developer, it is inspired by the effect section of Noises, a plugin made in collaboration with YouTuber and musician Hainbach.
The plugin features a multimode filter with lowpass, high pass, and notch characteristics with 2 or 4-pole options. You can control with classic cutoff, resonance, and output gain settings. Then, you have a bit crusher effect with bits, downsample, and mix controls. There is also a harshness control taken from the Reels plugin.
Handy, you can choose either to use the filter pre or post the crusher effect. So you can achieve different timbres. Further, you can activate and deactivate the individual modules giving you the option to use the filter or crusher standalone.
AudioThing Things Crusher is available now for an introductory price of 9
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
