Spitfire Audio launches LABS Harmonic Flights free instrument library
2022-5-29 10:57| ·¢²¼Õß: garden| ²é¿´: 614| ÆÀÂÛ: 0
ÕªÒª: Spitfire Audio has released a new LABS series instrument library in collaboration with Pianobook contributor Sage Reynolds, featuring double bass harmonics that are pitch-shifted and processed to crea ...
Spitfire Audio has released a new LABS series instrument library in collaboration with Pianobook contributor Sage Reynolds, featuring double bass harmonics that are pitch-shifted and processed to create deeply atmospheric string textures.
Bold and beguiling in equal measure, the gritty, evolving sounds of Harmonic Flights aim to add effortless movement and realism to your compositions.
Add movement and realism to your scores with these gritty, evolving string textures. High double bass harmonics are pitch-shifted and processed to create deeply atmospheric sounds ¡ª perfect for drama, fantasy or sci-fi.
The free library run in the Spitfire Audio app for Windows and Mac, supporting VST/VST3, AU and AAX plugin formats.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
