Pulsar Audio release Massive
2022-5-26 13:58| ·¢²¼Õß: 9395820| ²é¿´: 1024| ÆÀÂÛ: 0
ÕªÒª: Pulsar Audio has released Massive, a reproduction of the popular Manley Massive Passive EQ, which can be found in many a mastering studio the world over.Pulsar Massive is a component-accurate model of ...
Pulsar Massive is a component-accurate model of the original unit, emulating its parallel EQ design and the unique sound-sculpting abilities. With parallel EQ, band gains don't accumulate as in most other EQs, but rather recombine to produce natural-sounding corrections. The Pultec-like low-shelf filters allow a generous and tight low end, even at extreme boost settings. The high-shelf filters provide a pristine top end and air without harshness.
Just ask any experienced engineer to hear a ringing endorsement of passive EQ and its uses. Pulsar Massive's sound can be described as giving a creamy top-end, well-balanced mids, and a punchy low-end. Whether you're using subtle or extreme settings, audio never sounds over-equalized, but rather vivid and natural, keeping true to the nature of your source material.
Pulsar Audio
Pulsar Massive sports a host of modern features including visual curve editing, drive control, mid-side processing, auto-gain, oversampling, switchable transformer options, detailed metering and spectrum analysis and a responsive and resizable GUI.
Massive is available now from Pulsar Audio on intro for
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
