Magix releases Samplitude Pro X7 and Samplitude Pro X7 Suite
2022-5-25 11:41| ·¢²¼Õß: patent| ²é¿´: 1118| ÆÀÂÛ: 0
ÕªÒª: Magix releases Samplitude Pro X7 and Samplitude Pro X7 SuiteMagix has announced the release of Samplitude Pro X7, an update to the music production software for audio pros.Develop new ideas entirely f ...
Develop new ideas entirely from inception all the way to the finished arrangement in Samplitude. Enjoy access to a wide range of sounds and virtual instruments. to help you transform your ideas into sound: Whether solo artist or band, you¡¯ll always prepared for the best take.
Maintain a clear overview of every recording and see volume, frequencies and phase at a glance. Give your projects the decisive advantage in quality during mixing and mastering. Be the composer, producer and sound engineer. With Samplitude Pro X7. The master of pro audio.
Changes in Samplitude Pro X7
Improved export workflow.
Integrate external hardware effects as plugins.
Support for MIDI VST plugins.
Improved user friendliness.
Precise crossfade editing.
Improved design.
iZotope Ozone 9 Elements.
Celemony Melodyne 5 essential.
21 virtual instruments.
Samplitude Pro X7 for Windows is available for purchase for $399 USD. The upgrade from a previous version is $199 USD.
Also available is Samplitude Pro X7 Suite, which adds Steinberg SpectraLayers Pro 8 (including free update to version 9 on release), and the full version of the Sound Forge Pro 15 audio editor. Pro X7 Suite is priced $599 USD, while the upgrade is $299 USD.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
