Togu Audio Line Updates FREE TAL-Reverb-4 Plugin TAL Software has released an updated version of TAL-Reverb-4, a free reverb VST plugin for Windows, macOS, and Linux. Founded in the early 2000s, TAL Software has been making quality plugins and virtual instruments for years. They¡¯ve dedicated themselves to making the best possible products and mention on their site that they¡¯re ¡°not a marketing-driven company¡±; instead, their ¡°main focus is on the product itself.¡± This dedication to quality shows in the latest update of their TAL-Reverb-4 plugin. Reverb plugins are one of the most commonly used effects in music production. Still, each type of reverb has a different character and is helpful in various situations. Plate reverb, in particular, was one of the original forms of synthetic reverb. It worked by sending a signal through a metal plate attached to an enclosure via springs. The resulting reverb tone has been used in all genres but perhaps most recognizable in big, distant-sounding drums, popularized in many ¡¯80s pop hits- listen to the intro drums in ¡°Billie Jean¡± by Michael Jackson. TAL-Reverb-4 is designed to emulate old-school plate reverb and give your tracks that bright, retro feel. The interface is very user-friendly and straightforward to configure. The plugin features five primary modifiers: main, spatial, EQ, Input, and mix. The ¡°main¡± and ¡°spatial¡± controls determine most of the reverb tone. Users can select the size, diffusion, and delay before moving on to the ¡°spatial¡± control, which can add stereo width. A majority of the reverb tone comes from these initial controls, but it is possible to modify it further. TAL-Reverb-4 also has a built-in EQ so that producers can chop off the highs and lows of their reverb to help it fit better in the mix. Another great feature of this plugin is its built-in sidechain. Select an input, and your reverb will duck and create space for other tracks right away! Users can also choose from a variety of included reverb presets. TAL-Reverb-4 works on Linux, macOS X 10.9 or higher, and Windows 7 or higher. It is compatible with a 64-bit host and DAWs that support VST, VST3, AU, and AAX formats. Download and installation are straightforward. Follow the product link to the TAL Software website, select your operating system/desired plugin format, and it¡¯ll immediately begin downloading. Download: TAL-Reverb-4 (64-bit VST2/VST3/AU/AAX plugin format for Windows, macOS, Linux) https://tal-software.com/products/tal-reverb-4 |
