New Step Sequencer For iOS & Mac, OODA, Features Generative ¡®Wormholes¡¯ OODA is a MIDI step sequencer, available for iOS & Mac, that features interactive and semi-generative controls. What makes OODA unique is that you can connect arbitrary steps together using conditional ¡°wormholes¡± to add structured (or random) variation to your sequences. Another unique feature is that OODA¡¯s underlying model is decoupled from its voices. This allows you to interact with your sequences and create melodic variations in real time, without affecting your groove. Features: Record sequences up to 64 steps with the in-app keyboard or an external MIDI device Interact with your sequence on the fly using four ¡°action¡± buttons Link together steps using conditional wormholes to create structure and variation Create complex patterns of melody and rhythm using four independent voices Change voice speed independent of sequencer speed Comes with ten factory presets to give you an idea of what OODA is capable of Explore a deep, yet focused set of parameters Sequencer Settings Grid size (4¡Á4 or 8¡Á8) Sync voices to sequencer rate Sequencer rate Sequencer direction Shift amount (semitones) Live toggle rests and skips Wormhole Patcher Conditionally ¡°reroute¡± your sequence by connecting arbitrary steps Per-step wormholes Destination and normal steps per wormhole Trig conditions and probability for moving through each wormhole (see below for list) Voice Settings Four voices with independent settings Enable/disable Rate of play (in beat time from 16 bars to 32nd T) Includes unique note values based on the Golden Ratio for maximum generative fun! Length of note (10% to 100%) Variety of rules for selecting notes from active step (see below for list) Pitch offset Unique pattern control for creating rhythms and polymeters, now with step options Easily add holds, ties, accents (positive and negative), ratchets, and trig conditions MIDI velocity and channel Flexible Connectivity Use in a compatible audio unit host like AUM, or in standalone mode Control multiple instruments at once with five MIDI outputs One for all voices together, and one for each voice by itself Sync to the tempo of other devices using Ableton Link or MIDI clock (standalone) Send MIDI clock to external synths (standalone, experimental feature) Connect to Bluetooth MIDI devices Modulate OODA¡¯s parameters in a compatible AUv3 host (audio unit) Eight unique MIDI CC outputs derived from OODA¡¯s sequencer model Sequencer X, Sequencer Y, Sequence Phase, Action OR, and per-voice random Includes macOS app Ooda Video Tutorials: Pricing and Availability OODA is available now for $7.99. |
