Soundiron announces Aeolian Fan Harp
2022-4-30 10:19| ·¢²¼Õß: arturiam| ²é¿´: 833| ÆÀÂÛ: 0
ÕªÒª: Soundiron announces Aeolian Fan HarpSoundiron announces Aeolian Fan Harp instrument emulation. The instrument was based on the concept of a traditional ancient Greek wind harp, created by Dust Bowl Gu ...
Soundiron announces Aeolian Fan Harp instrument emulation. The instrument was based on the concept of a traditional ancient Greek wind harp, created by Dust Bowl Guitars and recorded by John Valasis a Greek-born composer, producer and sound designer in his Athens based studio.
Aeolian Fan Harp is a unique hand-made instrument created by Dust Bowl Guitars. Based on the concept of a traditional ancient Greek wind harp, this 12-stringed non-fretted holy body instrument incorporates a 120mm PC fan under the strings near the bridge to produce its own wind! And rather than nylon strings, it uses steel-wound strings and electric guitar pickups. When plucked while the fan is off, it has a sound similar to a baritone electric guitar. Powering up the fan generates a lush steady drone, but the real magic begins when you bow, scrape, gliss or excite the strings and set off extraordinary cinematic clusters, sound effects and undulating drones. This experiment was built over three long months and sampled in outstanding detail by Soundiron contributor John Valasis and Konstantinos Sakkas.
This nearly 14GB library includes a close stereo microphone position as well as a direct stereo pickup line out, so you can dial in an electric or acoustic sound just the way you like it with the help of our handy modular FX rack, full of amp and speaker simulators, multi-FX and custom convolution reverb impulses.
Contents
The Kontakt interface includes a suite of automation-ready sound-shaping controls to give you total creative flexibility. You have control over swell, attack, release, offset, vibrato, filter, pitch (coarse & fine), articulation switching, cross-fading and layering, and so much more. We've also included 20 unique sound-designed custom FX presets to give you lots of creative options.
This library comes with an adaptable LFO system, with selectable LFO shape, modulation target parameter, speed, intensity, tempo-syncing and fade-in time. You can also apply your choice of 12 lowpass, high-pass and FX filters, with assignable modulation targets such as velocity, modwheel, expression, after-touch, key position and step-sequencer table control. Our customizable arpeggiator offers a velocity table and control over arp direction, timing, swing, randomization and duration. We¡¯ve included a key and scale lock system to constrain your notes to common scales and keys for easy melodic composition and live performance.
The interface is rounded-out by our modular FX rack panel, with 18 different DSP effect modules that you can assign in any of 10 available slots, in any order that you wish. You¡¯ll find classic phaser, flanger, delay, distortion, amp and cab simulators, compressors, EQ, rotator and so much more. The Reverb effect includes our favorite convolution reverb impulse responses, including 99 different rooms, halls, chambers and outdoor environments, plus another 40 custom FX impulses to radically transform the sound and open up whole new worlds of musical possibility. We¡¯ve added a great bank of FX rack chain factory presets to get you started!
This nearly 14 GB library includes a powerfully flexible user interface built with endless sound-design possibilities, 20 hand-crafted atmospheric textural soundscapes, pads, drones, and custom FX presets designed to inspire your next composition.
It's built for the full retail version of Kontakt 5.5 or later
You can purchase Aeolian Fan Harp on sale now for only
$29 (MSRP $39) Hurry, Sale Ends May 10th
For more information please visit: https://soundiron.com/products/aeolian-fan-harp
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
