Digital Audio Denmark introduces Core 256 Digital Audio Interface
2022-4-29 08:36| ·¢²¼Õß: newnabie| ²é¿´: 1123| ÆÀÂÛ: 0
ÕªÒª: DAD - Digital Audio Denmark is proud to introduce the Core 256 Digital Audio Interface.In its simplest use case, the Core 256 is a Thunderbolt 3 interface with Dante, MADI and ADAT connections.The Thu ...
The Thunderbolt 3 connection supports:
256 bi-directional channels at 44.1/48 kHz
256 bi-directional channels at 88.2/96 kHz
128 bi-directional channels at 176.4/192 kHz
64 bi-directional channels at 352.8/384 kHz
The low latency CoreAudio driver supports Mac OS Monterey and Big Sur on both Apple Silicon and Intel hardware. ASIO driver for Win 10 and higher is also available.
The Dante interface supports:
128 bi-directional channels at 88.2/96 kHz
64 bi-directional channels at 176.4/192 kHz
Core 256 also features a built-in coax MADI interface with an option for a further two MADI, as well as 2 ADAT/SPDIF ports.
A built-in audio router allows the user to patch any input channel to any output channel, and even to multiple output channels simultaneously.
As if that wasn't enough, Core 256 also features DAD's renowned Pro Mon monitor controller functionality known from the DAD AX32 and Avid MTRX/MTRX Studio. On top that, the SPQ speaker EQ and bass management feature is also included.
All of this means the Core 256 can be used as just a high channelcount, low latency Dante and/or MADI interface for a computer (MAC and Windows) or as a full-blown Thunderbolt interface with one of the most advanced and flexible monitor controllers on the market, covering everything from mono to Dolby Atmos.
List price is  2695/$2995.
More details are available here:
https://www.digitalaudio.dk/ABOUT/Ne...ordid2169=1183
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
