Martinheterjag EasyVerb Martinheterjag EasyVerbAfter Gramophony and Wave Folder, developer Martinheterjag is back with EasyVerb, a simple and easy to use reverb effects with only two knobs. The reverb knob lets you dial in the desired type of reverb from rooms to halls to long shimmering reverbs. Then all that¡¯s left to do is to adjust the reverb level using the dry/wet mix knob and you¡¯re good to go. Despite its lack of more advanced controls, EasyVerb is a great tool if you just want a good-sounding reverb quickly. EasyVerb is a VST3 plug-in for Windows. |
