| Strikingly similar to the MIX BX the MIX CR and MIX KM mixer modules channel more classic mixer sounds into your Eurorack modular system. MIX BX I¡¯ve got a MIX BX; it¡¯s awesome. It¡¯s like upgrading the entire sonic presence of your Eurorack system. The sound is huge, driving itself into saturation with hardly a turn on the dial. I spent a lot of time searching for perfect kick drums and gnarlier basslines when all I needed was a MIX module from Feedback Modules. Now Feedback Modules has taken the design and format of the MIX BX that was based on an early 90s Boss BX-8 mixer and reworked it based on a couple of other well-regarded desktop mixers that were pouring grit into the sound of the early electronic music and techno movements. MIX CR The MIX CR is a 6-channel mixer module that¡¯s based upon the classic Mackie CR mixer that was favoured by electronic artists such as The Prodigy. It was what gave the Roland TB-303 that distorted sound we all like so much. Feedback Modules MIX CR Each channel has a mono input with gain control and then a Hi and Low EQ. Panning and volume control are available on knobs and the channel is rounded off with a nice and chunky but silent mute switch. There are also 2 auxiliaries that route out in mono and return in stereo to the Master section with individual levels. You get a stereo line-level output and a separate headphone output. MIX KM The MIX KM takes on the Boss KM-60 from the 1970s and is definitely a closer match in terms of looks. The facilities are exactly the same with the same layout and connections. Feedback Modules MIX KM Feedback Modules has produced channel strip modules based on the same mixers called the PRE CR, PRE BX and PRE KM. The PRE KM had a 3-position gain switch like the original KM-60. The MIX KM does not, instead it opts for the knob like the other two mixers. Presale limited supply The MIX KM and MIX CR are both being made in very small batches of 20. Feedback has opened pre-orders for this first batch for a special price of |
