sonicLAB releases Thermo self-regulating synthesizer for iOS
2022-4-22 07:46| ·¢²¼Õß: announces| ²é¿´: 1109| ÆÀÂÛ: 0
ÕªÒª: sonicLAB releases Thermo self-regulating synthesizer for iOS sonicLAB has announced the release of an iOS version of its Thermo self-regulating tone generator inspired by thermodynamic systems designe ...
sonicLAB has announced the release of an iOS version of its Thermo self-regulating tone generator inspired by thermodynamic systems designed and programmed by Sinan Bokesoy.
ThermoSynth extends the classical oscillator concept, it is a generative synthesizer at the waveform level, which does not express only static / interference waveforms but also an evolution of a sonic structure by internal communication and its actions inside certain controllable margins.
The oscillator of ThermoSynth establishes its own engine environment and begin its signal path with a waveform generator ( pure mathematical, not samples nor optimized tables ) rendering basic waveforms and capable of morphing in between. The 4 oscillators of the Thermo are in continuous interaction sending each other their signals thanks to a 4X4 feedback matrix.
Identical to the desktop Thermo version, the iOS app for iPad is available from the App Store for $22.99 USD (requires iPadOS 9.3 or later).
https://www.sonic-lab.com/pricingpurchase/
 https://shop.sonic-lab.com/cart/add/I-70-12-47
 https://apps.apple.com/app/thermosynth/id1619491705
¹ÙÍø£ºhttps://www.sonic-lab.com/thermo/
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
