BV-X Multimode Vocoder
2022-4-21 08:02| ·¢²¼Õß: sculptor| ²é¿´: 1006| ÆÀÂÛ: 0
ÕªÒª: Multimode VocoderReason Studios• Classic and futuristic vocoder effects• Simple set up with built-in synthesizer• Totally tweakable for deep sound designBV-X Multimode Vocoder is a m ...
Multimode Vocoder
Reason Studios
BV-X Multimode Vocoder is a modern take on the classic vocoder effect. It just got easier than ever to take your vocals in a new direction, even if you can¡¯t sing. BV-X is simple to set up but totally tweakable so you can focus on the fun stuff: experimenting and finding a sound that¡¯s right for you.
It comes with 150+ patches, ranging from classic vocoder sounds to out-of-this-world vocal processing. Whether you¡¯re looking for that classic vocoder sound, subtle harmonies, vocal sweeteners, or sci-fi sounds and robot voices¡ªBV-X has you covered.
BV-X Multimode Vocoder is included in Reason+. It is compatible with Reason 10.1 and
later. The included Combinator patches require Reason 12.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
