Cre8audio has announced the NiftyKEYZ, a Eurorack case with an integrated full-sized 49 key MIDI controller keyboard. NiftyKEYZ provides keyboard and MIDI control over four CV + Gate outs. NiftyKEYZ¡¯s MIDI implementation enables the use of each of its four CV + Gate outs as either a part of a fully patchable polyphonic instrument or on their own monophonically. Additionally, each voice can be split across multiple MIDI zones on the keyboard. For example, it is possible to create a four voice polyphonic instrument or a three voice instrument in part of the keyboard range, while splitting another voice into a monophonic instrument elsewhere. Waves Coupon Code FutureMusic For a limited time only! Up to 80% off all Waves Bundles. PLUS click the banner above or the Go button for an additional 10%! This is Waves best deal yet! Get yours today before this special ends! GO! Cre8audio NiftyKEYZ ¨C Eurorack case with full-sized 49key synth-action MIDI controller keyboard. Cre8audio NiftyKEYZ Distrokid Coupon Code FutureMusic The easiest way for electronic musicians to get their music onto Spotify, Apple Music, iTunes, Amazon Music, Tidal, Instagram, Facebook, TikTok, Pandora, Twitch & much more! Click the banner above or the Go Button to save 7% off of your signup! GO! Side View - Cre8audio NiftyKEYZ eurorack case NiftyKEYZ also contains performance functions that add expressivity and flexibility. These include a multi-mode arpeggiator, multi-mode clock synced LFO, aftertouch, velocity, sustain/latch mode, internal clock, expression out, and much more. All of these performance features are tied to CV outs, providing modulation and control possibilities. NiftyKEYZ¡¯s users will appreciate the integrated two-times buffered mults as well as the two-times outputs and headphone out with dedicated controls. NiftyKEYZ is also a capable USB and 5-pin Din MIDI controller and device. It can not only take MIDI in from computers and external MIDI devices, but also send MIDI back out to control them. Use NiftyKEYZ to control software-based instruments, other MIDI instruments, and/or let it be sequenced from DAWs, MIDI controllers, and sequencers. NiftyKEYZ Features: » Full size 49 key synth-action keybed with aftertouch » Four CV + gate outs ¨C can be split by keyboard zone and used polyphonic or monophonic modes » CV out for Aftertouch, Velocity, Modwheel / LFO, Expression » Clock ¨C internal clock and externally clock-enabled plus clock divider » Two-times buffered mults » Power output for modules: ¡ª +12V ¨C 1500mA ¡ª -12V ¨C 1000mA ¡ª +5V ¨C 1000mA » Multi-mode arpeggiator » Auto-chord function » Transpose function » Glide control » Swing control » Multi-mode clock synced LFO » Sustain pedal input (controls MIDI and gates) » Two volume controllable 1/4¡å TS mono outputs on its rear (mirrored 3.5mm outs on top) » Dedicated control for headphone out with 1/4¡å headphone jack on its rear » USB MIDI class-compliant ¨C no drivers needed » MIDI in via USB and 5 pin Din » MIDI thru via 5 Pin Din and USB Coinbase Promo Code Cre8audio¡¯s NiftyKEYZ is available now for $599.99 / |
