AngelicVibes Iota Mini
2022-4-19 08:22| ·¢²¼Õß: russlo| ²é¿´: 1127| ÆÀÂÛ: 0
ÕªÒª: AngelicVibes Iota MiniAngelicVibes Iota MiniAngelicVibes calls Iota Mini a ¡°free Trap VST¡±, but nothing stops you from using it for other styles such as hip hop and RnB, as well. It¡¯s a cool little ...
AngelicVibes Iota MiniAngelicVibes calls Iota Mini a ¡°free Trap VST¡±, but nothing stops you from using it for other styles such as hip hop and RnB, as well. It¡¯s a cool little ROMpler plug-in packed with 50 factory presets designed to spark your creativity. You can choose a preset and then use the knobs to tweak the filter cutoff, reverb and envelope (attack/release). On top of that, Iota Mini contains ten drum kits made up of six sounds each, each of which has its own level slider and pan knob.
Iota Mini is available for Windows and macOS in VST, VST3 and AU formats. The download size is 4.2 GB on PC and 2.2 GB on Mac.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
