Voxengo Shumovick 2.0 creative noise-padding plugin released April 16, 2022: Voxengo is pleased to release Shumovick 2.0, a creative dynamic noise-padding effect plugin for professional music production applications, available in AAX, AudioUnit, VST and VST3 plug-in formats, for macOS and Windows computers. Shumovick is a renamed and improved version of CRTIV Shumovick. It features the following changes: * Redesigned the user interface. * Added the "Pre-Delay" and "Stereo" parameters. * Made the "Dry Mute" switch persistent: its state is not affected by preset loading using plug-in's preset features. * Updated the noise generator to PRVHASH 4.3. * Changed noise gain range to -30..12. Shumovick plug-in for professional music production applications produces a creative dynamic noise-padding effect. This effect is most effective on beats and synth sounds used in electronic music production: EDM, hip-hop, and many others. The noise-padding effect created by this plug-in is correlated to the spectral content of the sound being processed. As a result, on beats, this creates mellow noise bursts that make bassdrum sounds a lot softer, with a bit of stereo-field enhancement effect. On synths, on the other hand, such noise-padding effect may boost the power and density of the sound. Shumovick can be also effective when used on sterile-sounding basslines where it can add a bit of ¡°pillowy¡± noise background. In practice, Shumovick can be also used on acoustic drum buses adding ¡°vintage¡± feel and aggression to them. When used on a full mix lightly, Shumovick can add a slight ¡°vintage¡± feel to the sound, make it slightly rougher, and add a stereo-widening effect: this is reminiscent of what a reel-to-reel tape and vinyl recording media does to the sound, naturally. Shumovick is a relatively CPU-demanding effect plug-in, so it requires a higher-end computer processor for a comfortable use. However, the CPU requirements can be lowered by adjusting plug-in¡¯s processing band count. Shumovick features: * Noise-padding signal envelope controls * Noise-padding signal equalization * Selectable processing band count * 64-bit floating point processing * Preset manager * Undo/redo history * A/B comparisons * Contextual hint messages * All sample rates support * Zero processing latency * User interface color schemes * Resizable interface * Retina and HighDPI support Shumovick is available for purchase online for US$49.95. Shumovick is free for Premium Membership owners. Discontinued CRTIV Shumovick can be upgraded to Shumovick for US$9.95. 20% OFF sale is currently in effect! Demo version of Shumovick can be downloaded freely at the Voxengo web site: https://www.voxengo.com/product/shumovick/?eref=fo |
