ScaleBud 2 Gives You New Ways To Work With MIDI & Scales On Your iPad
2022-4-12 11:14| ·¢²¼Õß: skillshare| ²é¿´: 658| ÆÀÂÛ: 0
ÕªÒª: ScaleBud 2 Gives You New Ways To Work With MIDI Scales On Your iPadDeveloper Cem Olcay let us know that they¡¯ve released ScaleBud 2 for iOS, a major update that lets you work with more than 110 scal ...
Developer Cem Olcay let us know that they¡¯ve released ScaleBud 2 for iOS, a major update that lets you work with more than 110 scales, unlimited keyboard rows, pattern pages, MIDI keyboard splitting, custom scales and more.
ScaleBud 2 can work as a standalone MIDI controller, or as an AUv3 Audio Unit plugin. You can use the ScaleBud 2¡¯s keyboard rows for controlling your MIDI apps.
You can also use ScaleBud 2 as a MIDI transformer. If you connect a MIDI keyboard to ScaleBud 2, you can control any of your ScaleBud keyboard rows with your hardware MIDI keyboard.
You can assign different MIDI channels, MIDI input ranges and you can transpose the incoming MIDI note¡¯s octave when you use ScaleBud 2 as a MIDI transformer. ScaleBud 2 lets you ¡®force¡¯ notes to a scale, and also lets you play chords with one key.
It also lets you split your MIDI keyboard and control multiple keyboard rows from a single hardware MIDI keyboard. For example, you can play chords on the left side of your MIDI keyboard and notes with the right side of your MIDI keyboard.
Pricing and Availability
ScaleBud 2 is available now for $4.99 USD.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
