SampleScience Retro Cazio: free virtual instrument plugin for macOS and Windows that brings back the sounds of the Casio MT-100 toy keyboard. Free plugin alert. For the new release from SampleScience, we travel back to the 80s to the lo-fi Casio toy keyboards. The MT-100 was a digital accompaniment keyboard that used the NEC D931 sound ship to generate its digital sound. It featured 20 classic-oriented sounds including organ, flute, trumpet, oboe, electric piano¡ as well as 12 rhythms (rock, pop, disco¡) Like many things from the past, these lo-fi toy keyboards including the MT-100 are very popular among electronic musicians today. Sample Science captured the sounds and melted them into a free plugin. SampleScience Retro Cazio Retro Cazio is a sample-based virtual instrument plugin that uses samples from the vintage Casio toy keyboard MT-100 from 1985. According to SampleScience, they have sampled the sounds from the MT-100 using high-end recording equipment. 20 retro toy sounds and a drum kit made it into the final Retro Cazio plugin. The samples are embedded in a plugin with an easy-to-use user interface. Then, you will find various tone-shaping parameters with which you can refine your sounds. There are lowpass/highpass filters, panning, a reverb, an ADSR envelope for the amp, pre-amp, glide, and a multi-wave LFO. Further, the plugin offers three different playing modes including monophonic, legato, and polyphonic. SampleScience Retro Cazio is available now as a free download and runs as a 64-bit VST, VST3, and AU plugin on macOS and Windows. |
