Eplex7 DSP releases Klerphonik Polyphonic Analog Synthesizer for Windows VST
2022-4-8 10:45| ·¢²¼Õß: zhanghong| ²é¿´: 725| ÆÀÂÛ: 0
ÕªÒª: Eplex7 DSP has released Klerphonik, a polyphonic virtual analog synthesizer with circuit emulation technology and time capsule technology.Eplex7 DSP team says:After last year's release of our Klerhaim ...
After last year's release of our Klerhaim monophonic analog synthesizer, we received many requests to produce a polyphonic synthesizer. We set to work hard and using our 17+ years of experience and virtual analog circuits technology and we developed another analog synthesizer.
Klerphonik, polyphonic VST analog-emulated synthesizer is a brand new plugin instrument with world's first time capsule technology. No, it is not only extended version / polyphonic version of Klerhaim N1. It is a brand new synthesizer with a completely different sound, color and extended options.
Klerphonik's sound is different ¨C more dynamic, more musical, subtle, more organic, colorful in the mids and highs, less bold and less saturated than Klerhaim N1.
Features:
2 analog type voltage controlled oscillators with saw, triangle, square, ramp, pulse 1, pulse 2 waveforms, volume control, octave selector, fine-tune control, LFO mod control, on / off switch (with complete analog emulation behavior like saturation, noise, harmonics, automatic pitch modulation / interference, etc.).
Analog temperature control (emulation of circuit temperature ¨C more temperature = more noise and interference signals).
Pink / white noise generator + on / off switch.
Analog exponential amp envelope with attack, decay, sustain, release controls and 7 different shapes of envelope for different sound / different type of modulation.
Analog exponential filter envelope with attack, decay, sustain, release controls and 7 different shapes of envelope for different sound / different type of modulation.
Voltage controlled low pass analog emulated filter with 12 / 24db slope and slope selector. With cutoff, emphasis, tracking and envelope mod. Controls.
2x LFO (with saw, triangle, square, ramp, pulse waveforms) speed and depth control.
Output analog saturation.
Glide and pitchbend controls.
Preset manager with 75 presets (leads, bass, pads, brass, stabs, acid, fx, special vintage sounds, keys).
Time-slot capsules and init presets ¨C these features are described in detail above.
4D Dimension analog chorus / flanger and a 14-bit digital vintage stereo expander which sounds completely different from regular choruses. The digital 14-bit stereo expander, modeled on 80's devices, will also deliver original sound from early digital records and a very unique color / type of sound.
Compatibility: VST plugin / EXE standalone for Windows, x64-bit / x32-bit.
Price: 59   There is an introductory price for first 100 customers of: 29,90 .
Price for all owners of Eplex7 Klerhaim N1: 15,90 .
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
