Take professional music and content creation anywhere with Duet 3With the release of Apogee¡¯s Control 2 software for iOS, Duet 3, Apogee¡¯s latest USB audio interface, is fully compatible with Apple iOS devices. Easily record and mix your projects on the go using your iPad Pro, iPad* or iPhone* with GarageBand or your favorite recording application. Duet 3 and your iOS device deliver the ultimate mobile workstation for music production, podcast recording or any type of content creation that requires high-quality audio inputs and outputs. Duet 3 is also compatible with macOS and Windows computers. Apogee Control 2 on iOS gives you complete touch screen access to all features and functions of Duet 3 including:
The Apogee Control 2 app is compatible with Duet 3 only. *A 12 ¨C 20W USB-C Power Adapter and an Apple Lightning to USB 3 Camera Adapter are required when connecting to any iOS device with a Lightning connector. See the following support article for setup instructions: Connecting Duet 3 to iPhone or iPad. |
