Audio Plugin Deals has announced that LitWAV¡¯s Stargate Synth virtual instrument is free to download for the next couple of days.
The rompler plugin contains 100 multi-sampled sounds, including bass, sub, strings, brass, pads, pianos and more.
Are you ready to open up new portals of infinite creativity and change the game? Have you been seeking a new source for dope unique synth sounds that are not from this dimension?
Litwav¡¯s sound design team literally went to the moon and back to bring you Stargate VST. Fully loaded with 100 custom presets designed to take your sound out of this galaxy and beyond. Hurry up and claim your copy of this magnificent sound arsenal so you can cook up heat hotter than the Sun itself.
