Ultimate Midi Plugin updates UChord VST with voicing inversion
2022-4-5 14:19| ·¢²¼Õß: vaponer| ²é¿´: 841| ÆÀÂÛ: 0
ÕªÒª: Ultimate Midi Plugin updates UChord VST with voicing inversion Ultimate Midi Plugin has announced an update for the UChord (Ultimate Chord Engine) plugin, a tool that is designed to help you create ch ...
Ultimate Midi Plugin has announced an update for the UChord (Ultimate Chord Engine) plugin, a tool that is designed to help you create chord progressions based on chord tables and a rhythm editor.
Version 1.2 adds voicing inversion, an edit mode button on the progression view, and a voicing filter option.
Voicing inversion features
Voicing Inversion affects the rhythm editor and voicing editor.
The inversion value is displayed as the shape and number of arrows on the chord item in the progression view.
In edit mode, the header area of the chord item acts as an option bar, and you can change the inversion state easily and simply by pressing the inversion buttons.
When saving a progression, the inversion state is also saved.
It is reflected in undo and redo state, and drag and drop of the chord item is possible even in edit mode.
UChord for Windows (VST) is on sale for $14 USD for a limited time (regular $49 USD).
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
