The Muro Box Is A MIDI-Controllable Mechanical Music Box
2022-4-5 09:48| ·¢²¼Õß: stargate| ²é¿´: 747| ÆÀÂÛ: 0
ÕªÒª: The Muro Box Is A MIDI-Controllable Mechanical Music BoxTeveofy Technology recently introduced the Muro Box, a electro-mechanical music box that can play any melody, because you can customize what it ...
Teveofy Technology recently introduced the Muro Box, a electro-mechanical music box that can play any melody, because you can customize what it plays using a mobile app. A MIDI input port is also available as an option, so the Muro Box can be used as a MIDI-controlled instrument.
Here¡¯s a video demo of playing the Muro Box using a MIDI keyboard:
  YouTube Á´½Ó£ºhttps://youtu.be/C52JgnO8_00
MIDI ÑÝʾÊÓÆµ£º
And here¡¯s an example, via Mark Steiner, of the Muro Box being played with the NuRAD MIDI controller:
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
