Multi MIDI Controller, Filter, Router & Sound Generator
2022-4-2 09:50| ·¢²¼Õß: apollo| ²é¿´: 985| ÆÀÂÛ: 0
ÕªÒª: Multi MIDI Controller, Filter, Router Sound GeneratorPangrus shared this video demo of the Multi, a multi-function MIDI device that can be used as a MIDI controller, sound generator, sequencer and mo ...
Pangrus shared this video demo of the Multi, a multi-function MIDI device that can be used as a MIDI controller, sound generator, sequencer and more.
The Pangrus Multi is available as a kit or fully assembled. It allows any kind of MIDI filtering and routing operation and it also functions as a bi-directional USB to DIN converter.
It¡¯s based on the Seeeduino XIAO, so you can program Multi as a simple sequencer, algorithmic arpeggiator, aleatoric patch generator and more.
The Multi is based on open source software, and several options are already available:
drone ¨C a six oscillators drone machine.
synth_sequencer ¨C a three oscillatorsmonophonic synth with embedded sequencer. It receives MIDI clock and note messages.
bytebeat player ¨C play salgorithmic music, with no instruments and no real oscillators, but a math expression that creates an audio output waveform as a function of time, processed 8000 times per second. The expression has six parameters accessible through the multi knobs.
midi converter ¨C a USB to 5 DIN bi-directional MIDI converter.
midi metronome ¨C takes the MIDI clock from the 5 DIN midi connector and generates a metronome click on the audio output, to allow acoustic musicians to synchronize their performance to an electronic setup.
Pricing and Availability
Multi is available in limited quantities, priced at $115 as a full kit or $140 assembled.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
